Vindicare assassin's weapons.
Grimm.
Have any of you read the Officio Assinorum?
The strength is entirely based on which ammo is chosen.
Shield Breaker rounds: Invulnerable saves cannot be taken against Wounds, glancing hits or penetrations.
Turbo Penetrators: Against vehicles, shots from a TP counts a strength 10. Against other targets TP rounds inflict d3 wounds
Hellfire: wound on a 2+
Direct quote.
Direct quote.
and where does that say what Strength x means?  What is the strength of a Turbo Penetrator fired at a non-vehicle? For that matter, what is the strength of a Shield Breaker round?  One ammo type against a specific target type has a Strength value.  For everything else, it is Strength x which uses its own rule for wounding.  It does not compare Strength against Toughness and as such it will never cause Instant Death. Otherwise it has  no stength value at all.  That's what Strength x means.
Against other targets TP rounds inflict d3 wounds.
You roll to hit. Which is  BS4 so vinidcare hits on 3s and then depending on the round used. You determine hits. Doesn't seem to difficult to me.
The Exitus rifle has no native strength. The strength comes from the round used.
The Vindicare is BS 8, not 4.
The weapon always wounds on a 4+ because of sniper, unless you use hellfire rounds or fire at a vehicle. The weapon actually never has a strength, always wounding on fixed numbers or counting as something.
I have never, until this day, seen anyone use circular logic to prove themself wrong. Thank you, chef.
The wording of the sniper rule, non-quoted, says that all confirmed hits require a 4+ to wound unless less is needed. Additionally, if a 6 is rolled for the wound, the weapon gains the rending special rule, which can negate possible FNP. Basically what that says, is that a weapon with a sniper rule is "basically" Str4. We all know that "basically" is not the same as "is."
Yes, with shield-breaker, if the target had an INVUL, it does not get said save, I like last editions version of this better (takes it away for a whole game (helped me kill a wraithknight)).
Yes, the turbo-penetrator (sorry, the immature part of my brain giggled) when fire at a vehicle is STR10, but against bodies is D3 wounds after the first wound connects.
Yes, the hellfire wounds on a 2+. Though this still does not indicate a STR.
So, what have we learned? Getting indignant when you're wrong, does not make you right. Class dismissed.
Other than the wrong ballistic skill how am I wrong?
The reason that the weapon is strength X is because of the ammunition used. Seems pretty straight forward to me.
Wounds are determined by a weapon's strength vs. target's toughness, yes?
If each type of ammo has it's own rules in determining wounds therefore the strength of the weapon is given by the round used.
Class dismissed.
If we could keep the condescension down, please, that would be shiny, guys. This is a forum for civilised discussion, not sniping at each other regardless of the unit being discussed.
I believe weapons with a Strength score of X are treated as being Strength 3 when firing at vehicles, by the way.
Also, who is Alex?
You have to wait for the full answer before buzzing in with the question.
The answer is: He is the Canadian born host of the American TV game show Jeopardy.
Also, the Strength of a sniper weapon when fired at a vehicle is given with the rest of the sniper rule.
"Against vehicles, shooting attacks from weapons and models with the Sniper special rule count as Strength 4."
There are more examples of Strength x weapons in other books than just the Vindicare's weapon.  And I know what D:OA says about the strength and different ammo types.  One single ammo type gives a different strength against one single target type so while technically the line is true it implies much more than what is there while still not saying anything about what you need to roll to wound with a shield-breaker round.  In the end, the answer to the questions
"What does strength X mean? How does that work in game?"  is covered in the Sniper rule of the basic rules.
  • 4 weeks later...
