Theredknight Posted February 28, 2015 Share Posted February 28, 2015 Ok, so to me, when one of these lands they should be placed on the ground off the stand. When they are on the stand, arent they classed as 'flying'? (clue Is 'flying' stand?) I couldn't find any rule to contrary but when on the stand they aren't blocking Los and take up less board space due to stand size. Thoughts guys? Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/ Share on other sites More sharing options...
Hesh Kadesh Posted February 28, 2015 Share Posted February 28, 2015 Models should be used on the base they are supplied with. Unless stated otherwise, there is no provision for taking it off the stand IIRC. The rules also state that when an Anvillus Dreadclaw deploys via Drop Pod Assault (something it MUST do), it counts as a Flyer in Hover mode as per Drop Pod Assault Special rules. I cannot remember if that same provision applies to a Kharybdis, I'm AFB until later. Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964515 Share on other sites More sharing options...
Carlson793 Posted February 28, 2015 Share Posted February 28, 2015 Confirming Drop Pod Assault on the Kharybdis as well. Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964517 Share on other sites More sharing options...
Theredknight Posted February 28, 2015 Author Share Posted February 28, 2015 So when it drops it come in on a stand? That makes a big difference for me, now all my str 6 missiles can point one way! I thought you had to drop it, like a drop pod. Because they have the name drop pod. But could be a good Los blocker to the enemy if off a stand? Is it the players choice then basically? Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964644 Share on other sites More sharing options...
Brofist Posted February 28, 2015 Share Posted February 28, 2015 In the description it says that it's 'landed', basically, but to treat it as a flier in hover mode. I don't think there's a hard and fast rule on this one. Is the cargo getting out? Then take it off the stand. Is it going to fly away next turn? Then keep on the stand. It's up to you :) Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964819 Share on other sites More sharing options...
Theredknight Posted February 28, 2015 Author Share Posted February 28, 2015 Well in that case, the kharbydis could have just improved for me, 10 pinning twin linked s6 shots at bs4? That's pretty much going to wreck some side armour if it can Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964839 Share on other sites More sharing options...
Brofist Posted February 28, 2015 Share Posted February 28, 2015 Where are those shots coming from? Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964868 Share on other sites More sharing options...
Theredknight Posted February 28, 2015 Author Share Posted February 28, 2015 From the 5 kharbydis storm launchers on the top. When on the ground they are in different directions like the death storm. However on a flying base they all switch down to point the same way as the claw is lifted on it's side. Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3964873 Share on other sites More sharing options...
Hesh Kadesh Posted March 1, 2015 Share Posted March 1, 2015 So when it drops it come in on a stand? That makes a big difference for me, now all my str 6 missiles can point one way! I thought you had to drop it, like a drop pod. Because they have the name drop pod. But could be a good Los blocker to the enemy if off a stand? Is it the players choice then basically? "Models and Base Sizes The rules in this book assume that models are mounted on the base they are supplied with. Sometimes, a player may have models in his collection on unusually modelled bases. Some models aren’t supplied with a base at all. In these cases (which are, in all fairness, relatively few and far between), you should always feel free to mount the model on a base of appropriate size if you wish, using models of a similar type as guidance." "FLYERS AND MEASURING Flyers have flying bases that suspend them above the battlefield. However, distances are still measured to and from the Flyer’s hull, with the exception of the vehicle’s weapons and Fire Points, which all work as normal. The base of a Flyer is effectively ignored, except for when: • The Flyer is in close combat, in which case models may move into contact with the vehicle’s hull, its base or both. • Models are embarking or disembarking from the Flyer, in which case the base of the Flyer is used as an Access Point." Should answer your questions regarding flyers and bases. If your meta is a lot more amenable to playing "as fluff seems" then I can't see why not; but for the purposes of what the rules say (this being the rules forum and all), this is what they say. Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3965301 Share on other sites More sharing options...
depthcharge12 Posted March 1, 2015 Share Posted March 1, 2015 I do believe the Anvillus pattern one states that models may disembark within 2" of it's bottom hatch but I'll have to check. Disembarking from the flyer base is probably better though. Link to comment https://bolterandchainsword.com/topic/304068-anvillus-kharbydis-landing/#findComment-3965366 Share on other sites More sharing options...
