Jolemai Posted March 2, 2015 Share Posted March 2, 2015 So, it's been brought to my attention that despite following the instructions, the tail wing on my Stormraven is the wrong way around. Having had it pointed out to me, I just can't understand how I managed to do it as it seems so obvious! What are my options here? It has two layers of paint on it (base and undercoat) and was put together using superglue (probably something like Locktite). Does the freezer method actually work? (At least I'm consistent. The wings on my Imperial Jetbike are on backwards too...) Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/ Share on other sites More sharing options...
Lucien Eilam Posted March 2, 2015 Share Posted March 2, 2015 A firm tap on a table should be enough to crack a superglue join apart. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966150 Share on other sites More sharing options...
JeffTibbetts Posted March 2, 2015 Share Posted March 2, 2015 So, it's been brought to my attention that despite following the instructions, the tail wing on my Stormraven is the wrong way around. Having had it pointed out to me, I just can't understand how I managed to do it as it seems so obvious! What are my options here? It has two layers of paint on it (base and undercoat) and was put together using superglue (probably something like Locktite). Does the freezer method actually work? (At least I'm consistent. The wings on my Imperial Jetbike are on backwards too...) The freezer trick absolutely works. I'd toss the poor bird in the ice box (on top of the turkey for added irony) for a couple hours and then do just as Lucien suggests. Should pop right off. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966169 Share on other sites More sharing options...
appiah4 Posted March 2, 2015 Share Posted March 2, 2015 Them boys at the forgeworld were pretty hammered the night they put together that Storm Raven of yours eh? :) Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966173 Share on other sites More sharing options...
elmo Posted March 2, 2015 Share Posted March 2, 2015 Mine is the same but I just say that it is more aerodynamic and ascetically pleasing ;) Just leave it as a conversion... Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966190 Share on other sites More sharing options...
Stercus Posted March 2, 2015 Share Posted March 2, 2015 Mine is the same but I just say that it is more aerodynamic and ascetically pleasing ;) Just leave it as a conversion... It might look ok aerodynamically, but all your control flaps are on the wrong side of the wings? Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966204 Share on other sites More sharing options...
appiah4 Posted March 3, 2015 Share Posted March 3, 2015 Mine is the same but I just say that it is more aerodynamic and ascetically pleasing Just leave it as a conversion... It might look ok aerodynamically, but all your control flaps are on the wrong side of the wings? There's nothing about the Storm Raven that looks OK aerodynamically and it makes no sense as an avionic vehicle in any way no matter how you build it, so you may as well go crazy with it. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3966945 Share on other sites More sharing options...
Brother_Angelus Posted March 3, 2015 Share Posted March 3, 2015 I did exactly the same thing. Had no choice but to break it off with force, reattach, and paint over the joint. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3967028 Share on other sites More sharing options...
elmo Posted March 3, 2015 Share Posted March 3, 2015 Mine is the same but I just say that it is more aerodynamic and ascetically pleasing ;) Just leave it as a conversion... It might look ok aerodynamically, but all your control flaps are on the wrong side of the wings? Yup, the elevators are at the front. But it does make it look like a more aerodynamic brick. ;) I am sticking with it... :) Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3967088 Share on other sites More sharing options...
Kaedes Nex Posted March 5, 2015 Share Posted March 5, 2015 Mine is the same but I just say that it is more aerodynamic and ascetically pleasing Just leave it as a conversion... It might look ok aerodynamically, but all your control flaps are on the wrong side of the wings? You don't back up into battle in reverse gear? Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3968690 Share on other sites More sharing options...
OrangeBob Posted March 5, 2015 Share Posted March 5, 2015 The freezer method works incredibly well. And luckily my wife gets a good laugh about, as she says, "my army guys being in the freezer." Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969500 Share on other sites More sharing options...
Stercus Posted March 6, 2015 Share Posted March 6, 2015 The lack of aerodynamic believability on the raven is one reason I own a stormeagle. However, as time passes im coming to think that in a galaxy of space wizards, an alternate reality of pure emotions, and both sentient mushrooms and diseases with feelings running around the place, basic physics may not be so important. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969589 Share on other sites More sharing options...
Lucien Eilam Posted March 6, 2015 Share Posted March 6, 2015 It's not an aeroplane, it's a vehicle that needs to operate everywhere from the void, to airless moons, to the dense atmosphere of high-gravity gas giants. It should be obvious to anyone that it can't rely on aerodynamic principles to work. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969743 Share on other sites More sharing options...
appiah4 Posted March 6, 2015 Share Posted March 6, 2015 It's not an aeroplane, it's a vehicle that needs to operate everywhere from the void, to airless moons, to the dense atmosphere of high-gravity gas giants. It should be obvious to anyone that it can't rely on aerodynamic principles to work. It has to work against aerodynamic principles in case of atmospheric flight though, and its designated role as a gunship carrier makes certain that majority of its operation is atmospheric. Ergo, its design is counterproductive to what it is made for. It makes no sense, and good luck getting something like that to fly with any kind of precision. It's laughable design, any engineering junior could have come up with something that made a million times more sense. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969755 Share on other sites More sharing options...
elmo Posted March 6, 2015 Share Posted March 6, 2015 It is safe to say that "given enough thrust, anything can be made to fly." At least for one definition of flying :) At the end of the day, the Stormraven is a flying brick so whether the elevators are correct or not is a matter of opinion as to what looks best ;) If anyone is interested, mine can be found in my siggi, but I have also used the CHS extension kit which has the advantage of making the whole model looks better. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969817 Share on other sites More sharing options...
Stercus Posted March 6, 2015 Share Posted March 6, 2015 Eh.... I like the stormraven. It's ugly and brutal. Under current technology it would barely fly, but then it's not operating with current technology, it's operating with M31st technology. If you showed any technological item from today to a human from two hundred and eighty centuries in our past, they'd probably think that it wouldn't work, or at least have no comprehension of how it did. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969841 Share on other sites More sharing options...
Lucien Eilam Posted March 6, 2015 Share Posted March 6, 2015 It has to work against aerodynamic principles in case of atmospheric flight though, I'll see your atmosphere and raise you grav-plates, ceramite plating and big off engines. and its designated role as a gunship carrier makes certain that majority of its operation is atmospheric. Considering the nature of what it carries, that doesn't follow at all. There's a dizzying array of worlds in the Imperium and it has to work on all of them. Solutions to the extreme worlds where conventional flight is impossible would work equally well on an Earth-like world. Link to comment https://bolterandchainsword.com/topic/304157-stormraven-tail/#findComment-3969856 Share on other sites More sharing options...
