Kingofmottinos Posted March 8, 2015 Share Posted March 8, 2015 Hi to everyone! I'm planning to make a battle mat myself instead of buying one (60 euros is too much for me to spend in a battle mat) and I found this tutorial http://ufozerozero.blogspot.it/2014/12/miniature-wargaming-battle-mat-project.html. When he says " aforementioned substrate of some kind" I find myself wandering what should I buy... I did a quick search online and I really can't decide. The cheaper option I found is this http://www.ebay.com/itm/3MM-MATT-PVC-FOAM-board-1-piece-297-x-210-A4-/360540464311?pt=LH_DefaultDomain_3&var=&hash=item53f1e2e4b7 Do you think it would work? Link to comment https://bolterandchainsword.com/topic/304397-questions-about-battle-mats/ Share on other sites More sharing options...
Grotsmasha Posted March 9, 2015 Share Posted March 9, 2015 I'd be concerned about 3mm board flexing, it'd take it up to 5mm maybe....besides that, looks good :tu: Cheers, Jono Link to comment https://bolterandchainsword.com/topic/304397-questions-about-battle-mats/#findComment-3971870 Share on other sites More sharing options...
Kingofmottinos Posted March 9, 2015 Author Share Posted March 9, 2015 Thanks for the advise! I'll try to search a 5mm one. One more thing: If I use the caulk like the tutorial says, can I still roll up the mat? Link to comment https://bolterandchainsword.com/topic/304397-questions-about-battle-mats/#findComment-3972167 Share on other sites More sharing options...
JGeils81 Posted March 9, 2015 Share Posted March 9, 2015 I wouldn't think you could roll up foam board, usually not that flexible. I figured you would need something more latex or vinyl ah I was thinking of a permanent mat, I see what this is now. does the silicone stick to vinyl? I don't know...otherwise basically any time of thin material that it wont seep through before it dries should work. roll plastic, tarp, vinyl mat etc. Link to comment https://bolterandchainsword.com/topic/304397-questions-about-battle-mats/#findComment-3972301 Share on other sites More sharing options...
Kingofmottinos Posted March 9, 2015 Author Share Posted March 9, 2015 I wouldn't think you could roll up foam board, usually not that flexible. I figured you would need something more latex or vinyl ah I was thinking of a permanent mat, I see what this is now. does the silicone stick to vinyl? I don't know...otherwise basically any time of thin material that it wont seep through before it dries should work. roll plastic, tarp, vinyl mat etc. I could have found something cheaper and even easier to do In the comments he says "We've been using the mats for about a month now. Playing Malifaux on Fridays and for shooting videos and playing games here and there. They've been rolled, folded, thrown around, stretched, terrain scraping on it... etc. So far, they are all intects and no chipping or anything. It's been really holding up to abuse." Link to comment https://bolterandchainsword.com/topic/304397-questions-about-battle-mats/#findComment-3972351 Share on other sites More sharing options...
