/Night Lords/ 750 starting.
Hello, B&C.
Our local community will have 40k tournament for newbies. And let me try 30k list.
1 troops, 1 hq required.
The problem i see is a lack of Range AT.
Couse it's not good idea to pop up Battle Wagon wth MBombs just to realize that u will be charged by nobz.
Chaplain 130
w Power Axe, Artificer, MBomb
Contemptor 210
w Kheres, Plasma Blaster
Tactical Squad 10 150
Night Raptors 8 260
3 Chainglaves, Artificer, MBomb
Comments, and can someone tell me how NL playing on 2-2,5k. Couse i have no idea how to build army on this format and i have thing: i always make square lists. No single units, no units with 7,9 members.
Sorry for my english :)
https://bolterandchainsword.com/topic/304514-night-lords-750-starting/
Swap the Kheres Contemptor for a Deredeo with Autocannon and Missile Launcher (you'll need to find 15 points, iirc) and you'd be set on Ranged AT at that points level. I'd also try to find a way to get your Chaplain a Jump Pack and slap him with the Raptors since thats where he'll be the most useful.
Lascannons, are better, yes, but its still only 2 TL shots vs the 4 TL S8 Sunder Shots + 3 S6 Always-Hits-Side-Armor shots of the missile launcher for pretty much the same cost.
If you have the cash and modelling skills to do it, you could use a Box / Contemptor body to replace the Deredeos.
If anything, a Sicarian would be a better bet since it has the Volume of fire and can have 2 LasCannon Sponsons for the same cost. It also ignores Jink and I doubt you'll be facing Fire Raptors or Storm Eagles at this range.
Taking the Sicarian also frees up some points.
Challenge?
Uf huf, sweet challenge.
Mb i'll not resist this temptation and take this challenge.
Yeah who wants to run a mortis dread a Sicaran and a Scorpius at that points level?
You wouldn't have any fun or friends afterwards. Challenges are made to be beat!!!!
If you can rock at least 2 turns of night fighting you'll find yourself at an advantage, then again if you get to go second that will help. Sprinkle in a few power weapons and melta bombs for good measure, see what points you've got spare after you add the support option whether you want something swift or heavy is up to you.
Didn't say it was a good idea, just doable if someone wanted that particular challenge tongue.png
Good luck fitting a model requiring 1000pts in a 750pt list.
The model doesn't require a 1000 points; taking a RoW does.
So while technically right, it doesn't mean he's proscribed from fielding it.
hesh kadesh, just cheked 1st book. You'r absolutely right.
depthcharge12, it'll be 40k torney. And i know at least two guys, one will be with 3 centurions with Severin Lot for invisabiliti or FNP and EW.
Another one will be with Thunder Wolves boeng.
So, i dont think dat anyone will be dissatisfied with just one sicarian ;)
Lol #thatswhyidontplay40k #tryhards
Can't you still use the Delagatus to get the RoW for under 1000 points? I thought that was his whole purpose...
Edit: or can't you use Sevatar?
