Carrack Posted March 15, 2015 Share Posted March 15, 2015 I was priming up a rhino a few nights ago using krylon black primer. It has worked well before for me. It appeared to be applied correctly yet when I retrieved it from my covered porch an hour or so later there was a grey filmy residue covering the model almost completely. It was raining and I used the last of the can. Was it the humidity? The dregs of the can? Operator error? Do I need to strip it? It will not wash off, but if I run a fingernail across it it reveals the black primer as it should be. Sorry I don't have pictures. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/ Share on other sites More sharing options...
FashaTheDog Posted March 15, 2015 Share Posted March 15, 2015 Might be humidity. Fun fact about priming when raining, there is loads of moisture in the air to mess with your spray paint. Depending upon how bad the residue is, you might be able to still use it by gently washing it off. This also depends on how good a painter you are too. A modest quality paint job or worse should be unaffected by a little primer issue provided that you clean it up sufficiently. For instance, when my primer gets fuzzy from too much humidity, I gently brush it away with a worn toothbrush to smooth and it tends to be just fine (next time it happens to a Carnifex though, I'm leaving it, painting the model white, and giving the Fex bunny ears with the name Fluffy). If you paint to a high standard, then you may want to strip it. Since there is a residue, however, you may want to test to make sure your paint job isn't going to flake off as though the model were covered in mold release. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977598 Share on other sites More sharing options...
Carrack Posted March 15, 2015 Author Share Posted March 15, 2015 Thanks I tried washing off with hot water and a rag, I will try with a toothbrush. At least it wasn't the land raider I got the same day. ): Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977622 Share on other sites More sharing options...
Stoic Raptor Posted March 16, 2015 Share Posted March 16, 2015 Using aerosol spray of any kind on a model (whether it's primer, paint, or varnish) is so dependent upon temperature and humidity. If it's too cold, the paint will be gummy and thick. If it's too hot and/or dry, the paint will dry before reaching the model and you get a granular finish. If it's too wet, moisture gets trapped in the coat and you get what you experienced, or frosting with a clear coat. Basically, the farther the outside weather is from standard room temperature and humidity, the worse your results will be. To save your model, try gently sanding the primer - not to remove it, but to restore it to a smooth surface. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977901 Share on other sites More sharing options...
FashaTheDog Posted March 16, 2015 Share Posted March 16, 2015 Since we are talking about weather and its effect on spray paint I will add this. You can use cold weather to your advantage. If you keep the can of paint warm on a day well below freezing and then coat something before the can and paint cools, then the paint will contract while it dries and crack. On large flat surfaces (like Rhinos) it gives this neat marbled effect. What is important is that the paint goes on warm and then dries in the bitter cold, which can be tricky unless you spray a small number of parts at a time or have a heated interior spray area. Fortunately if you lack the latter, you are an endotherm so you can warm that can against your body under your coat between pieces! Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977902 Share on other sites More sharing options...
Carrack Posted March 16, 2015 Author Share Posted March 16, 2015 Using aerosol spray of any kind on a model (whether it's primer, paint, or varnish) is so dependent upon temperature and humidity. If it's too cold, the paint will be gummy and thick. If it's too hot and/or dry, the paint will dry before reaching the model and you get a granular finish. If it's too wet, moisture gets trapped in the coat and you get what you experienced, or frosting with a clear coat. Basically, the farther the outside weather is from standard room temperature and humidity, the worse your results will be. To save your model, try gently sanding the primer - not to remove it, but to restore it to a smooth surface. I fear I will be forced to strip the primer. I have tried gently sanding it with everything from a toothbrush to fine sand paper to no effect. The amount of pressure/ friction required to get rid of the residue will damage the model. Incidentally I also tried rubbing alcohol and a bleach based cleaner, as well as good old soap and warm water, none of which worked. I'm pretty new to the hobby thanks for the advice. Next good weather day I will prime as much as I can. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977989 Share on other sites More sharing options...
Carrack Posted March 16, 2015 Author Share Posted March 16, 2015 Since we are talking about weather and its effect on spray paint I will add this. You can use cold weather to your advantage. If you keep the can of paint warm on a day well below freezing and then coat something before the can and paint cools, then the paint will contract while it dries and crack. On large flat surfaces (like Rhinos) it gives this neat marbled effect. What is important is that the paint goes on warm and then dries in the bitter cold, which can be tricky unless you spray a small number of parts at a time or have a heated interior spray area. Fortunately if you lack the latter, you are an endotherm so you can warm that can against your body under your coat between pieces! Interesting, I live in a pretty warm place, Texas, and do not think I will see any more cold days this year. I may try this technique with an old freezer I have in my garage though tomorrow. I think I will test it out on some empty sprues or if I can find a flat bit that doesn't have any foreseeable use first though. I'll store the bit in the freezer, take it out and spray it down, then let it dry in the freezer. I'll let you know the results. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3977992 Share on other sites More sharing options...
Carrack Posted March 17, 2015 Author Share Posted March 17, 2015 My freezer experiment didn't do anything special. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3979889 Share on other sites More sharing options...
FashaTheDog Posted March 17, 2015 Share Posted March 17, 2015 For reference I used a Rustoleum flat white and have only done it on days below zero. I'm not sure what the exact temperature was, but the news said the high for the day was -9oF when I last did it a few months ago. Wish I could be more help. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3979944 Share on other sites More sharing options...
Carrack Posted March 18, 2015 Author Share Posted March 18, 2015 Thanks for the help. I did get some models primed without the fuzziness by drying them indoors. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3979964 Share on other sites More sharing options...
Spazmonkey Posted March 19, 2015 Share Posted March 19, 2015 I Live is Queensland Australia very hot and humid place.... I can only paint during the middle of the day, sometimes in the morning if it is dry enough If i paint in the evening I always have issues with my paint going grey or seperating. Enamel paints coming out matt instead of gloss. grey paint going black as well. Humidity and heat will have a massive effect on can spray paint. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3981075 Share on other sites More sharing options...
Stoic Raptor Posted March 19, 2015 Share Posted March 19, 2015 That's why I don't use spray primers any more. Where I live, it's too cold for 4-5 months out of the year, too hot for 1-2 months, and rainy over 50% of the time. Needless to say, even during the best months (May-June, September-October) it can be days until ideal weather rolls around for spray painting. I live in an apartment building and do not have a garage or basement and there's no way I can set up an airbrush station (due to compressor noise and the fact that I paint at the kitchen table). So I typically use brush-on primer - Vallejo makes an acrylic-polyurethane surface primer that is unparalleled. It comes in a variety of colors and can be brushed on or airbrushed. It's self-levelling for very thin coats, super durable and has a good surface for paint to adhere to. If you're having trouble with sprays, try this. You will not regret it. Link to comment https://bolterandchainsword.com/topic/304656-bad-primer-job/#findComment-3981083 Share on other sites More sharing options...
