Need help achieving color
Banks
Hey guys,i'm currently working on a flawless hosts scheme for my chaos marines,but i don't want the bright bright pink of Emperor's children, i want something more along the lines of this.
http://smg.photobucket.com/user/KingKonstad/media/P1010441.jpg.html
I really like the pink the painter has achieved here,and was wondering if anyone could perhaps point me in the direction of what colors were used in this mix for the pink.
Thank you in advance.
https://bolterandchainsword.com/topic/304658-need-help-achieving-color/
Start with Screamer Pink as a base, layer on Pink Horror, shade in the recesses with either Druchii Violet (for a more purple tone) or Carroburg Crimson (for more reddish tone), clean up with Pink Horror, line highlight with Emperor's Children, final spot highlight with Fulgrim Pink or mix 1:1 Emperor's Children:Skull White.
Or just use Screamer Pink, shade with either of the above, then clean up with Screamer Pink, line highlight with Pink Horror, spot highlight with Emperor's Children for a deeper pink.
So i took your advice,and i think i've found a pretty good mix,i mix emperors children,white and then i directly mix in Druchii Violet into the color rather than washing it over,though i'll do that for the recesses. But mixing in the druchii violet also helps to water it down a bit since i'm using an airbrush as well. Thank you guys
