Kingofmottinos Posted March 16, 2015 Share Posted March 16, 2015 Hi! I need to convert a baneblade to a stormblade and the main problem is the plasma blastgun... I can't find anyone who sells the gun separately, not even on the bitz stores or ebay. Do you know any online store that sells it? If not, is there a way I can make the gun myself? Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/ Share on other sites More sharing options...
Jolemai Posted March 16, 2015 Share Posted March 16, 2015 Perhaps Blood and Skulls Industries might be of use? Machinator also has an account on here which may help for questions. Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3978393 Share on other sites More sharing options...
Kingofmottinos Posted March 16, 2015 Author Share Posted March 16, 2015 Perhaps Blood and Skulls Industries might be of use? Machinator also has an account on here which may help for questions. Thanks for the fast reply! :) The gun on the link would be really good if it wasn't so short... I'll check Blood and Skulls Industries' site :) Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3978396 Share on other sites More sharing options...
Machinator Posted March 17, 2015 Share Posted March 17, 2015 I have schemes for a larger one, but it might be awhile.... Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3979340 Share on other sites More sharing options...
Kingofmottinos Posted March 17, 2015 Author Share Posted March 17, 2015 Hi! I'm the dude who contacted you on eBay two days ago! XD I think that two nova cannons should be fine, I'm only thinking about the turret: can I use the one provided with the baneblade or should I buy the heavy tank turret from your shop!? Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3979372 Share on other sites More sharing options...
Machinator Posted March 17, 2015 Share Posted March 17, 2015 Either will work but I think my Heavy Tank Turret will give it a more balanced look with the added mass. The Nova Cannon is also designed to work with my heavy turret so that would make things a bit easier for you. Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3979520 Share on other sites More sharing options...
Kingofmottinos Posted March 17, 2015 Author Share Posted March 17, 2015 Either will work but I think my Heavy Tank Turret will give it a more balanced look with the added mass. The Nova Cannon is also designed to work with my heavy turret so that would make things a bit easier for you. Ok, thank you very much, sooner or later I'll order 2 nova cannons + 1 turret :) Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-3979553 Share on other sites More sharing options...
hendrik Posted April 9, 2015 Share Posted April 9, 2015 here's how i converted mine: http://i210.photobucket.com/albums/bb281/amorfatipictures/IMG_20140525_202716_zpslyfkrwir.jpg http://i210.photobucket.com/albums/bb281/amorfatipictures/IMG_20140525_202739_zpsts7ixd31.jpg http://i210.photobucket.com/albums/bb281/amorfatipictures/IMG_20140525_202725_zpsc07cvxkl.jpg it's basicly plasticard tubing inserted into the stormlords gun insert, and copper wiring turned around both tubes. I used greenstuff to sculpt the end of the gun. Do not that you'll need to add extra weights in the turret itself, to cancel out the weight of the gun itself. the best part is, this way you can still insert the shadowsword gun barrel to make all the other variants! Link to comment https://bolterandchainsword.com/topic/304703-converting-baneblade-to-stormblade/#findComment-4002764 Share on other sites More sharing options...
