angrom Posted March 26, 2015 Share Posted March 26, 2015 Hi all This might be a silly question but is it possible for an inquisitor who pick burner of world warlord trait to move and use his orbital strike? I Know that it is considered as a Ordnance shot, but after all the shot come from an orbital spaceship It doesn't really make sense that the inquisitor cannot move during the same turn because of the huge recoilof a weapon he didn't even shoot with, does it? In the same order of idea is it possible for Karamazov who have the relentless to use his orbital strike call and move in the same turn? even if he is in a vehicle? Link to comment https://bolterandchainsword.com/topic/305156-inquisitor-with-burner-of-world/ Share on other sites More sharing options...
Isiah Posted March 26, 2015 Share Posted March 26, 2015 As per RAW the OS is treated as firing a heavy weapon, so no moving unless relentless. But I would agree that as charging is allowed, it does seem silly. Maybe the Inq had to stand around targeting which precludes normal movement, who knows. But once it has been called in, he's freed up to make a charge move if he needs to. Cheers I Link to comment https://bolterandchainsword.com/topic/305156-inquisitor-with-burner-of-world/#findComment-3988145 Share on other sites More sharing options...
Lucien Eilam Posted March 26, 2015 Share Posted March 26, 2015 This might be a silly question but is it possible for an inquisitor who pick burner of world warlord trait to move and use his orbital strike? No. The only exception given to the Ordnance rules is that you can charge in the Assault phase. In the same order of idea is it possible for Karamazov who have the relentless to use his orbital strike call and move in the same turn? Yes. That's what Relentless does. even if he is in a vehicle? Karamazov cannot embark on vehicles or in buildings. Link to comment https://bolterandchainsword.com/topic/305156-inquisitor-with-burner-of-world/#findComment-3988166 Share on other sites More sharing options...
angrom Posted March 26, 2015 Author Share Posted March 26, 2015 ok Thanks, Another question. when you use the orbital strike on a target with Karamazovdo you have to use his other weapon or the unit weapons on the same target or can you choose another one? Link to comment https://bolterandchainsword.com/topic/305156-inquisitor-with-burner-of-world/#findComment-3988241 Share on other sites More sharing options...
Isiah Posted March 26, 2015 Share Posted March 26, 2015 As it says, treat as per standard rules for shooting a heavy weapon :). So all normal shooting restrictions / rules would apply unless otherwise stated. Cheers I Link to comment https://bolterandchainsword.com/topic/305156-inquisitor-with-burner-of-world/#findComment-3988271 Share on other sites More sharing options...
