Blender-Dread - Red or Black?
Quixus
Putting aside the fact that blender dreads just aren't very good anymore, I'd say the Furioso is the superior choice for the following reasons:
-Av13 front armour is much much better than Av12 (obviously).
-Against WS4 opponents, the DC Dread will get marginaly more hits in on the charge (3 vs 2.66 for the Furioso), but in subsequent rounds, both will get the same amount of hits.
Depends what you want, Furioso is pretty much superior to the DC in every way due to AV13, even though the DC has an extra attack.
That said, if you have elites left, take a Furioso (But a frag cannon is usually better msn-wink.gif ), if not; Cassor is a troops choice!
Cassor also requires a formation to take. He is not a blood angel codex unit.
He has a datasheet. He is like Bel'a'kor (sp?) in that regard.
Unless his datasheet says he may be taken as a part of a Codex Blood Angel detachment the only way to take him is the formation. Last I looked at him I saw no such thing.
That makes no sense. Why would they have a FOC slot assigned if the only way to use them was as part of a Formation?
Sorry Lysere, but it's unanimously accepted you can take him without the need for any formation. He is just a unit for the Blood Angels army. If you need proof of this, the Archangels detachment mentions you taking Captain Karlean as a possible Commander for the force. This wouldn't be possible given the Deathstorm formation, but it is as he is just a HQ choice for Blood Angels.
Eurgh, mobile posting. Should be obvious where my reply is :P
So that you have stuff in the formation considered to be a troop should it matter. That and everything must have a role.
Still it is a data sheet, just like any other unit in C:BA. Are you saying none of the units in that box are Blood Angels?
To nail the coffin shut:
Faction: The unit’s Faction will be shown with a symbol. The symbols for these Factions are defined in Warhammer 40,000: The Rules. The units described in this book have either the Blood Angels or Tyranids Faction
Cassor's and all the other BA units' datasheets in that book clearly sport a winged blood drop. I don't think that makes them Tyranids.
What book tells you what units make up a codex Blood Angels army? The codex. None of the deathstorm units are mentioned in Codex: Blood Angels, therefore they are not valid options for Codex: Blood Angels unless their rules say otherwise. Nowhere in Deathstorm does it say any of those units can be taken as part of Codex: Blood Angels.
The nail in the coffin is every imperial armor book which lists marine units that may be taken as part of Codex: Blood Angels despite not being in the codex itself.
Cassor (and the other three) are classified as a datasheet for Faction: BA. Each entry in the Codex is classified as a datasheet for Faction: BA. Ergo, a CAD/BSF/FTSF/ASF/AD can pick any combination of them to fulfill the slots in that detachment.
A formation is a completely different entity and where it is the case, it tells you they are a formation. Blood Angels have the following Formations:
Perhaps you can point us to which one of those is called Cassor the Damned?
No, the units in a detachment need not be from the same codex, they have to be from the same Faction. SoB: Deathstorm clearly states that Cassor is of the BA faction. Ergo Cassor can be taken in any BA detachment.
All units belong to one of the many Factions that are fighting in the 41st Millennium. This will often be represented on the unit’s Army List Entry with a symbol, the key for which can be found to the right. A unit’s Faction applies regardless of how you choose your army, but is especially relevant to Detachments because many state that you can only include units of a particular Faction.
Also:
Restrictions
All units chosen must have the same Faction (or have no Faction).
RESTRICTIONS
This Detachment cannot be your Primary Detachment.
Your Warlord can never be chosen from this Detachment.
All units chosen must have the same Faction (or no Faction).
All units chosen must have a different Faction to any of the units in your
Primary Detachment (or no Faction).
RESTRICTIONS
All units in this Detachment must have the Blood Angels Faction (or be fortifications).
I'm pretty sure the other BA specific detachments have similar restrictions only requiring a certain faction, not that the units come from a certain book.
I did do some research, but that's not the issue. The issue is still adjusting to the wording of 7th. I played for two months before I learned that models outside of a challenge could swing on the guys in one if he ws all that was left. The whole faction thing is a 7th thing and I guess it plays a bigger part that I interpreted. Old supplements told you how they worked with the codex, Deathstorm doesn't.
Oh well, Ive got plenty of Melta so if my friend ever gets his Blood Angels going Ill be ready to slag Cassor. Hopefully we will see some more dread characters as the various marines get new stuff.
No offense, but that's said in the rulebook!
It is, but its a small snippet of a section with very few changes. 7th was hardly a change from 6th in some places so it is easy to not realize changes.
