AJB2K3 Posted April 5, 2015 Share Posted April 5, 2015 Is there some secret to this device?I can't get the drum belts onto the mandrel so have ordered the ez mandrel in hope that that works! Link to comment https://bolterandchainsword.com/topic/305635-dremel-sanding-drum/ Share on other sites More sharing options...
Carlson793 Posted April 5, 2015 Share Posted April 5, 2015 Been a while since I've touched my Dremel, but as I remember: loosen the screw in the mandrel, slide the sanding drum down over it, tighten the screw to tighten the drum. The screw compresses the rubber shaft, forcing it to press into the sides of the sanding drum. Link to comment https://bolterandchainsword.com/topic/305635-dremel-sanding-drum/#findComment-3998606 Share on other sites More sharing options...
AJB2K3 Posted April 6, 2015 Author Share Posted April 6, 2015 Been a while since I've touched my Dremel, but as I remember: loosen the screw in the mandrel, slide the sanding drum down over it, I am unable to get the sanding drum to slide down. I have even taken the rubber section off and tried! Link to comment https://bolterandchainsword.com/topic/305635-dremel-sanding-drum/#findComment-3999096 Share on other sites More sharing options...
JGeils81 Posted April 8, 2015 Share Posted April 8, 2015 do you have the correct sizes? never remember it being that much of an issue with mine, I also have the kind you loosen the screw in the middle. I dont use sanding drums on plastic though(if thats what youre trying to do)too aggressive and gums up easily. Link to comment https://bolterandchainsword.com/topic/305635-dremel-sanding-drum/#findComment-4001915 Share on other sites More sharing options...
AJB2K3 Posted April 12, 2015 Author Share Posted April 12, 2015 do you have the correct sizes? never remember it being that much of an issue with mine, I also have the kind you loosen the screw in the middle. I dont use sanding drums on plastic though(if thats what youre trying to do)too aggressive and gums up easily. Yeh, the rubber wouldn't compact enough. The speedclick version has a softer rubber and works first time. Link to comment https://bolterandchainsword.com/topic/305635-dremel-sanding-drum/#findComment-4005600 Share on other sites More sharing options...
