Guardsman1275 Posted April 20, 2015 Share Posted April 20, 2015 I was looking for some WWII minitatures when I found these http://wargamesfactory.com/webstore/world-war-2/ww2-russian-infantry-28 I love the way these look and was wondering if I could use these as guard minis. I could use rifles for lasguns or take arms off of shock troops. I could use the included LMG's for autocannons? I could also try to fit them into heavy weapon team models. For tanks I could just paint my LRBT's light green and put a red star on the turret. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/ Share on other sites More sharing options...
Father Mehman Posted April 20, 2015 Share Posted April 20, 2015 A guy I used to play with had all an all Third Party Guard force. Nothing wrong with it in my eyes. As long as they fit 28mm "Heroic" Scale, have at them ! Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4014926 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 I found these models for heavy weapons, they are not on round bases, but I could mount them on regular sized bases. this makes the heavy weapons look more like heavy weapons http://www.waylandgames.co.uk/russian-forces/9995-28mm-russian-heavy-weapons so I will have a unique looking guard force that costs less! Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4014941 Share on other sites More sharing options...
Dam13n Posted April 20, 2015 Share Posted April 20, 2015 You could, although they'd require some conversion work. For variety, you could look at Warlord Games: Bolt Action. They make models for pretty much all WW2 "factions" including a good selection of Russian models. They are also well priced for what you get. I'd be careful with the Plastic Soldier Company 28mm models as they're resized from 15mm (1:100) scale models. As such the level of detail isn't as good as models specifically designed for 28mm. A point to note is that historical 28mm tends to be a little smaller than GW's "heroic scale" 28mm, so they'll look a little scrawny. That means they'll look more appropriate next to a Space Marine in terms of scale, but placed next to a standard Guardsman, they'll look a little small. Also a GW store or GW run event will probably not let you use them, as they won't be "GW models", and they tend to be sticklers for that sort of thing. If you're OK with that, then there's nothing stopping you. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4014965 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 What would I need to do to convert them, I think that the AT guns look enough like autocannons to the point where trying to convert them would make them look worse. Anyways I live in Hanover NH so there is not a GW store for probably 50+ miles, the closest I have been to being New York. As for the rifles being lasguns I think that they look alot like the preatorian pattern or kreig pattern lasguns. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015001 Share on other sites More sharing options...
WarriorFish Posted April 20, 2015 Share Posted April 20, 2015 They look the right size, but aren't heroic scale. I reckon they'd look ok with a bit of 40k added, for example the bits you get on Guard sprues :) Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015018 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 I know that historic models are smaller, but the bases are the same size, and guardsman models from GW look to big anyways, being around the same hight as a space marine. For tanks should I leave them the same, hellhounds look russian and so do LRBT's but are there any good alternate models that are the same size that you have seen? Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015034 Share on other sites More sharing options...
WarriorFish Posted April 20, 2015 Share Posted April 20, 2015 They're 28mm so are the same, it's just a matter of the heroic scale thing but that isn't much of a deal once you get loads of models together. Guard tanks are very retro so WWII tanks fit in well :) Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015055 Share on other sites More sharing options...
Carraigf Posted April 20, 2015 Share Posted April 20, 2015 Hey guardsman,I've some experience with wargames factory from their vikings range. The figures are a bit bigger than most 28mm but overall still skinnier than your avg cadian but would do fine on the table top. There's lots of 3rd party las guns out there, mad robot and victoria miniatures do some nice ones. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015110 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 I do not plan to buy special lasguns because of the cost. I think that their rifles will be fine, but if they come and look horrible I can buy some custom lasguns. Are wargames factory miniatures good, they are cheap but I was wondering if the quality is very low along with the price? Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015128 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 Also should I paint the tanks a lighter green than usual to make them look more like russian tanks in WW2 Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015136 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 actually victoria makes all their models 30 mm so their bits won't work Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015141 Share on other sites More sharing options...
WarriorFish Posted April 20, 2015 Share Posted April 20, 2015 Victoria's stuff works with the Guard range, we've several comrades who use the pieces very nicely on their armies so they should work with other 28mm miniatures. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015152 Share on other sites More sharing options...
CommodusXIII Posted April 20, 2015 Share Posted April 20, 2015 The major issue I'd see with using historical-scale minis is Line of Sight/cover determination. As always, though, whatever you agree with your opponent goes! Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015171 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 Also my FLGS sels heavy weapons team bases that I can use for the russian weapons. Do you think that these models will look enough like guard it I use the included weapons? I do not want it to look like a russian infantry group standing next to warhammer tanks. Do you think they will blend in? I am taking wyverns hellhounds and LR demo's Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015236 Share on other sites More sharing options...
WarriorFish Posted April 20, 2015 Share Posted April 20, 2015 With a bit of 40k bits added and a different paint job they shouldn't look too Red Army. Maybe with the right colour scheme they'd look more Valhallan..? Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015252 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 what 40k bits do you think I should add, this is the first time I have tried something like this and do not know where to start, could one bit to add be a chainsword in the officers off hand? what should I do about voxes and melta's? Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015254 Share on other sites More sharing options...
WarriorFish Posted April 20, 2015 Share Posted April 20, 2015 Nothing too fancy, you could just give them the pouch and water bits and the odd helmet on helmetless models and that'd go a long way. Voxes can just be glued to the backs of models and the classic weapon swap always works - so long as you can find a suitable base model. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015256 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 actually I can use the provided LMG's as meltaguns, while they do not look a ton like them melta models are 12$ a piece and I am not paying that mush for one bit I will use. as for voxes I can glue the one's I have onto the mini's I will have to be careful though. Actually now that I look at them again they do not look that far off from guard. I like them as an alternative to the cadian and catachan models, which are not my cup of tea. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015260 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 for grenade launchers and flamers I will use the GW models since I have like 10 lying around. I will also have LOTS of extra russian bits because of the amount of extra sprues it comes with. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015264 Share on other sites More sharing options...
Guardsman1275 Posted April 20, 2015 Author Share Posted April 20, 2015 I could also just put skulls on everything how do you think I should, if at all change my vehicles? They do not look very valhallan. For anyone that knows uniforms they are their summer uniforms. In fact they look more steel legion than anything, but that does not really fit the theme of my list, so puting gas masks on them wouldn't really work. The heavy weapons I will be using will probably be a little small and look kind of different but the glory of warhammer is that I can just make up a regiment and say that they have different pattern weapons than most guard. I am very excited about the models, though it will probably be a while until I get them, if they turn out very well I may post them on this thread or start another thread on the forum. Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4015323 Share on other sites More sharing options...
captain sox Posted April 21, 2015 Share Posted April 21, 2015 hell YES! Do this now! Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4016211 Share on other sites More sharing options...
Guardsman1275 Posted April 21, 2015 Author Share Posted April 21, 2015 well I do not have the time or money to do this for a while, but I should have some of the models by june and I will post pictures on this thread and open a new thread on the forum once, in the very distant future, I get all my stuff painted. Do you like the models, do you think that the weapons, both rifles and heavy weapons, look 40k enough to put on the tabletop? Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4016265 Share on other sites More sharing options...
march10k Posted April 22, 2015 Share Posted April 22, 2015 I definitely like the bolt action 28mm models, and I also agree that they're a bit scrawny when compared to GW's 28mm models. They look fantastic, though, I'm going to start painting those shortly. The variety is great, everything from finnish ski infantry to some kind of Indian auxiliaries in cowboy hats fighting for Britain in Burma! Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4016385 Share on other sites More sharing options...
Guardsman1275 Posted April 22, 2015 Author Share Posted April 22, 2015 I have my final plans I will use the long barreled version for a lascannon and the short barreled version for a autocannon http://www.hobbybunker.com/products/28mm-russian-45mm-anti-tank-gun-ww2g28001 I will replace the weapons on these models for cadian lasguns http://wargamesfactory.com/webstore/world-war-2/ww2-russian-infantry-28 for painting I will paint the uniforms kakhi the sholder pads and helmets a lighter green. I will paint the guns green and silver. I will paint the heavy weapons dark grey. Vehicles I will paint a lighter green, in a similar shade as the helmets tell me what you think of my plans Link to comment https://bolterandchainsword.com/topic/306419-russian-guard-regiment/#findComment-4017071 Share on other sites More sharing options...
