brother_contagion Posted April 21, 2015 Share Posted April 21, 2015 I remembered hearing that Destroyer Weapons negate Reanimation Protocols because of the "remove from play" rule, but I can only find that under the Stomp Table, not the Destroyer Table. So I'm assuming that it wouldn't negate it since the Destroyer Table doesn't "remove from play", unless there's something in the Necron Codex that says Reanimation Protocols can't be taken against Destroyer Weapons. Link to comment Share on other sites More sharing options...
Kristoff Posted April 21, 2015 Share Posted April 21, 2015 RP specifically mentions not working against hits from Destroyer Weapons or Attacks that have "remove from play" in their special rules. It is at the end of the first paragraph. Link to comment Share on other sites More sharing options...
Fibonacci Posted April 22, 2015 Share Posted April 22, 2015 You wont find it in the BRB. Its in the codex. "Reanimation Protocols rolls may even be taken against hits with the Instant Death special rule, but cannot be used against hits from Destroyer weapons or any special rule or attack that states that the model is ‘removed from play’." Link to comment Share on other sites More sharing options...
