Reusing plastic bags to make plasticard
Aqui
The link sends me to an empty page.
I'll have to see if I can work why.
EDIT: Just been to the site's main page. That won't show in browser either blink.png
Perhaps the site is having problems. If I can get the link to work again then I'll repost it.
Edit 2: Seems to be working again... blink.png
Just in case it goes again, this is the Youtube link:
Can you paint HDPE plastic and not have the paint eternally flake off? Normal plasticard is polystyrene, not HDPE. Heating polystyrene is supposed to be very bad for you.
I must admit I'm not sure. I do know that if you melt certain types of plastic, the fumes are toxic, or at the very least unpleasant.
Perhaps it's better to find other alternatives after all...
I wouldn't expect flat plastic sheets when doing that. I know that plastic bags like that burn very easily.
It's true that sprue can be melted, but it's more like a floppy noodle, it would never turn liquid and be able to be poured again. It also burns easily. All you can really do is draw out a section into a thin line.
If you want to be able to pour them resin is the way to go and far safer.
Might be interesting to try for an experiment, but if I want uniform thickness plastic, I am more likely to just use some plasticard of the desired thickness. I might be tempted to do something like that if I were trying to do larger vacuform projects though… Emperor knows, I certainly have a never-ending supply of plastic bags from the grocery store…
