exinfris001 Posted May 3, 2015 Share Posted May 3, 2015 As the title says, I need help with weathering silver power armor. Does anyone have or know of a tutorial on weathering say Grey Knights or Silver Skulls. I'm trying to make them very dirty and battleworn. Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/ Share on other sites More sharing options...
Bryan Blaire Posted May 3, 2015 Share Posted May 3, 2015 Are you looking for chipping, mud effects, blood splatter, demon gore, etc.? Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4028353 Share on other sites More sharing options...
exinfris001 Posted May 3, 2015 Author Share Posted May 3, 2015 Dirt, dust, light rust etc. Want to make it look like their armor has seen a lot of wear and tear with little maintenance. Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4028361 Share on other sites More sharing options...
Bryan Blaire Posted May 3, 2015 Share Posted May 3, 2015 For dirt and dust, you could use weathering powders (this will likely give the most realistic effects). Weathering Powder Tutorial by Secret Weapon Miniatures Weathering Tutuorial over on DakkaDakka You can also simply dry brush your chosen dust and dirt colors onto the model in the proper gathering places (lower legs and feet, in crevasess around the upper legs and arms), but if you want to get some real gritty look, you'll want to explore possibly getting some sand glued into those areas where you want the most build up. For unpainted Ceramite like the Grey Knights are supposed to be, there's not necessarily an under-layer to reveal, so you don't want to paint a darker color underneath, however, you probably want to mimic the pitting effect by mixing some black with your silver paint or doing a few layers of Nuln Oil to darken spots on the armor, then highlight the lower edge with bright silver to fake a recess. As far as rust, a couple of tutorials here on B&C: http://www.bolterandchainsword.com/topic/244447-rust-effect-technique-how-to/ http://www.bolterandchainsword.com/topic/293177-studio-workshop-how-to-paint-rust-effects/ http://www.bolterandchainsword.com/topic/292243-studio-workshop-how-to-paint-rust-with-dry-pigments/ Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4028365 Share on other sites More sharing options...
Carlson793 Posted May 3, 2015 Share Posted May 3, 2015 A possibility is to use a bright silver base and dry brush a 'darker' silver or bright steel where you want it 'damaged'. Might give the impression of discoloration and the early effects of wear and corrosion without full on rusting. Or maybe get a very small amount of Nuln Oil on a cloth, allow it to soak into the cloth, rub it on an edge, and wipe it off while it's still wet. Would discolor the silver. Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4028385 Share on other sites More sharing options...
Hexagon Sun Posted May 3, 2015 Share Posted May 3, 2015 I used a few things on my GK land raider (check the WIP link in my sig for more photos), including chipping, pigments, inks and also oil washes for streaking although it's subtle. The chipping was is a dark silver with some added black as Bryan Blaire suggested and works well, especially you use a few different silvers as it looks more natural. I'm sure you could take it a lot further than I have if you wanted to. A good source of weathering techniques is the FW masterclass vol 1, which i used extensively on the tank. http://i1147.photobucket.com/albums/o551/hexagonsun1/Grey%20Knights/Land%20Raider/finished_left_side_zpsfn2btdzy.jpg Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4028540 Share on other sites More sharing options...
exinfris001 Posted May 6, 2015 Author Share Posted May 6, 2015 Thanks to you all. Many different techniques to try. The idea behind this is a Marine force with little to no support, that has seen a lot of action. Their armor is dingy, dirty, and in need of serious service. Link to comment https://bolterandchainsword.com/topic/307036-weathering-silver-power-armor/#findComment-4032912 Share on other sites More sharing options...
