markham82 Posted May 3, 2015 Share Posted May 3, 2015 Hello Brothers I'm building a chapter master for the ETL and have come across a bit of a problem. I'm using the lightning claw arm from the space marine commander and I'm struggling to fit the shoulderpad. It seems like the power cable at the bottom of the arm is getting in the way. Has anyone experienced this or did I do something wrong? Thanks in advance Link to comment https://bolterandchainsword.com/topic/307059-having-a-problem-fitting-shoulderpad-to-lightning-claw/ Share on other sites More sharing options...
Grotsmasha Posted May 3, 2015 Share Posted May 3, 2015 Try rolling the shoulder-pad forward to the front of the model, you may need to trim the inside of the pad/cable as well. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/307059-having-a-problem-fitting-shoulderpad-to-lightning-claw/#findComment-4029062 Share on other sites More sharing options...
