honeybadger33 Posted May 4, 2015 Share Posted May 4, 2015 Hey guys. I recently bought myself an airbrush and am getting started with it on my models. Or Im trying to at the moment. Most of the paint I own is GW Citadel paint. Can I use Citadel Paints in my airbrush if I thin it down? If so, how do I mix it (How much do I thin) and what is the best way of transfering the paint from one pot to another to the cup. Thanks Link to comment https://bolterandchainsword.com/topic/307075-airbrush-paints-question/ Share on other sites More sharing options...
TotalInsomnia Posted May 4, 2015 Share Posted May 4, 2015 So you definitely can use your GW paints along with basically all other acrylic paints. I either use a brush or a dropper to transfer the pant depending on how much i need. I thin my paint in the airbrush cup although that may not be the best practice. I start by putting in thinner and add paint till i get about a 1 to 1 mix. If it seems good i spray it on something (not the mini and not something absorbent either) and go from there. After a while you will get a feel for it. You can thin paint with water but I get better results from a tamiya thinner and glaze medium mix. Link to comment https://bolterandchainsword.com/topic/307075-airbrush-paints-question/#findComment-4029271 Share on other sites More sharing options...
Firepower Posted May 4, 2015 Share Posted May 4, 2015 Like Total said, any acrylic is fine, more or less. I mix in the cup using Vallejo airbrush thinner. Rather than going on a set formula like thinner/glaze combos, whatever you use you should simply shoot for a skim milk consistency. Link to comment https://bolterandchainsword.com/topic/307075-airbrush-paints-question/#findComment-4029280 Share on other sites More sharing options...
