SM Scouts as alternate Scions
I had a thought as I am starting to build my small Scion detachment:
I was thinking of using SM Scout bodies with the extra Scion bits to make my Commander and Command squad. Has anyone tried this? Curious if the Scout chests may be too wide to equip the Hotshot Volley gun on...
If noone has, i will probably try it and see..
https://bolterandchainsword.com/topic/307312-sm-scouts-as-alternate-scions/
I haven't bought any Scions, but I have toyed around with combining Scouts and Cadians. It just doesn't look right. Cadians might be comically over-sized for humans, but they are still too small to combine with Marine body parts, even Scouts.
Of course, if you don't mind a bit of size discrepancy then it would work. I'm not sure how much you'd need to change in order to make Cadian arms fit though. In all of the combinations I tried I was using Scout shotgun arms (which coincidentally make gorilla Arbites if you put them on a Cadian body).
Here you go
Out of the box it wont fit due to the width of the torso and the moulded pouch on the scouts chest.
If you cut the pouch off and did a bit of GS to angle the barrel arm then it could fit
http://i51.photobucket.com/albums/f372/rbrewster101/IMG_4241_zpsc8uzevsm.jpg
Big gap
http://i51.photobucket.com/albums/f372/rbrewster101/IMG_4242_zpsskry0ux8.jpg
Size difference
http://i51.photobucket.com/albums/f372/rbrewster101/IMG_4244_zpskfhnj2wm.jpg
