Lord Asvaldir Posted May 10, 2015 Share Posted May 10, 2015 About to start working on some tanks for my renegades&heretics force, going for a more worn out, poorly maintained equipment look. Any suggestions on what colors to use to get a rusted/worn effect? Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/ Share on other sites More sharing options...
Ovidius Incertus Posted May 10, 2015 Share Posted May 10, 2015 Vallejo Model Air Rust, Hull Red, Mahogany all give nice rust effects of various tones, but "older" rust. (Doombull Brown could be subbed for the Hull Red, probably.) An orange like Jokaero will give a "new" rust effect. Vallejo Model Color Camo Black Brown gives an interesting corrosion/dark rust color. Apply via sponge or you can use hairspray technique (here you'd want to use multiple rust colors and lay them on in patches and in varying thicknesses to get a varied effect). You can use streaking effects after if you want to go really far. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4036709 Share on other sites More sharing options...
Bung Posted May 10, 2015 Share Posted May 10, 2015 I would recommend the rust effects from Model Mates, its pretty good and as it dries it gives alot of different shades. http://www.modelmates.co.uk/product-category/pots-rust-effects/ Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4036785 Share on other sites More sharing options...
Gurth Posted May 10, 2015 Share Posted May 10, 2015 Take a few shades of brown, red, and/or orange — exact colours are completely unimportant. For large rusted areas, paint on one colour as a base. If you then apply a wash of another of these colours, you can enhance the rust effect dramatically by dabbing any of the other colours into the still-wet wash with a fine brush, aiming for random shapes. Rust streaks are easy to do by thinning some rust-coloured paint so it flows well, and then swiping downward with a fine brush from where the actual rust is supposed to be on the model. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4036865 Share on other sites More sharing options...
Lord Asvaldir Posted May 10, 2015 Author Share Posted May 10, 2015 All helpful responses thanks. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4037279 Share on other sites More sharing options...
Larkyn Posted May 15, 2015 Share Posted May 15, 2015 You know, for what is is, GW's Typhus Corrosion and Ryza Rust aren't terrible. I have a couple of Killa Kans from the Stormclaw box that I used them on, and they didn't come out that bad, I think. Quick and easy for sure. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4042739 Share on other sites More sharing options...
Lucio Posted May 17, 2015 Share Posted May 17, 2015 I've tended to use Ryza Rust, washed with Sepia, with Typhus Corrision mostly being the very edges of the rust patch. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4045560 Share on other sites More sharing options...
Atia Posted May 21, 2015 Share Posted May 21, 2015 i use Valejjo Rust colours (Rust and Dry Rust) Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4052189 Share on other sites More sharing options...
Morticon Posted May 21, 2015 Share Posted May 21, 2015 Check out Decoy Ops' threads - especially the the Warhound titan one. Link to comment https://bolterandchainsword.com/topic/307377-painting-rust/#findComment-4052224 Share on other sites More sharing options...
