  • 1 month later...
  • 3 weeks later...
Matt varnish won't do much to protect it.
If you need to protect a model from wear and tear, use gloss varnish.
If you need to completely remove the shine from everywhere on a model (which you probably will if you've gloss varnished it), matt varnish it. Be aware that this will flatten any metallics too.
If you don't need to do either of these things, don't do them. Acrylic paint on plastic or resin miniatures is pretty resilient.
It depends what you want to achieve.
It's terrain, so you might want to protect the paint from getting scratched when models are moved around on it.
The point is, matt varnish won't protect it from scratches. Matt varnish is good for killing shine and fixing weathering powder, that's about it. If you want to protect it from scratches, you'll need to gloss varnish it.
If you do gloss varnish, you'll want a final coat of matt varnish to kill the shine.
Personally, I'd just fix the paint every now and then.
I tried a few times to roll dice on them, it's literally impossible, especially if you kit out the table as a city, all those nooks and crannies ended up with a lot of cocked dice.
So then I figured out that plastic lids are the best to roll on!
Oh wow, yeah almost immediately we outlawed rolling on the battlefield at the home table... Between losing a die under a terrain piece, or knocking over a model or cocked dice it was just not happening any more... Box lids or old school high lipped dinner trays work great... Edited by Canadian_F_H
I did testors glosscoat on all 6 tiles (it took a two - three cans), and then army painter matte sealer on them all (I think this only took up half a can, as it's got a lot in it). I don't have a sheen or shine at all to my tiles and they're pretty resilient. I also store them in their bag with a piece of 2x2 cardboard between each piece and it fits fine.
Edited by revarien
  • 5 months later...
I hope this is ok - I didn't see it suggested anywhere yet and it might help someone else. This stuff is really good for creating a tough protective coat on scenery and miniatures, I've used the aerosol cans on models and found it really toughens them up. Much cheaper than GW rattle cans.
http://www.wattyl.com.au/en/find-the-right-product/wood-care/Interior/DoorsandWindowFrames/Clears/WattylEstapolinteriorPolyuerthane.html?preview=true
Edited by Golf33
  • 2 months later...
  • 1 year later...
As for rolling dice on the table ... i made this dice tower as a terrain piece so no missing dice on the table and everyone see's what was rolled...
it has a PVC tube going through the middle with baffles placed strategically inside ....
It has been painted since :blush.: , i should take a pic of the finished thing actually :biggrin.:
anyways just another idea to stop your terrain being marked by the Dice Gods..!
Mithril
Register a new account
Sign in
