ronin_cse Posted May 20, 2015 Share Posted May 20, 2015 Hello all, Now that the Ad Mech releases are over and done with I will be able to start on my next project. I have already decided to start a 40k Ultra Marine army and I have always wanted to do a HH army so I figure I may as finally jump into 30k. So I have a couple questions of what I should work on (and I didn't notice a sticky covering this or anything, apologize if there is a thread for this already). Obviously I need to get Tempest at some point (or at least I really really want it) and I need the red Legion book. I am less sure about how to start building tac squads. I have 2 boxes of plastic tac marines from GW waiting to be assembled and I have been eyeing the new HH Ultramarine upgrade kits. It doesn't look like MKVII armor is THAT different from MKIV so I was wondering if I could get away with using the Ultramarine Invictarii and Praetorian kits with what I have, or if I should really get MKIV shoulders and/or legs as well. Obviously I know there aren't any hard rules and of course I can do what I want, but I want to do this right. I eventually want a HH army that I could take to a HH Open without feeling like I cut too many corners or something ;). Thanks! Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/ Share on other sites More sharing options...
Hyperion Posted May 20, 2015 Share Posted May 20, 2015 If you want to do it "right" then I would avoid all Mk7 armour. It's certainly a (slightly) cheaper way of building your army, but I suspect that you'll only go back and change them later! We're all a bit obsessional about detail, and those minor differences tend to catch the eye. As you say, you're completely free to do whatever you want - it's YOUR army - but it also sounds like you're just as hobby-OCD as the rest of us! Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051218 Share on other sites More sharing options...
Atia Posted May 20, 2015 Share Posted May 20, 2015 if you want to do it *right* (and during the HH era), than you should try to avoid mk vii and viii =) Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051220 Share on other sites More sharing options...
Kol Saresk Posted May 20, 2015 Share Posted May 20, 2015 Unless you're doing a Siege of Terra army, Sarum-pattern helms or the SoH variant. I think it started with a "g"? Those all use Mk VII Helmets. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051230 Share on other sites More sharing options...
Atia Posted May 20, 2015 Share Posted May 20, 2015 Unless you're doing a Siege of Terra army, Sarum-pattern helms or the SoH variant. I think it started with a "g"? Those all use Mk VII Helmets. the SoH variant is called mantilla pattern if i remember it right^^ :P Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051244 Share on other sites More sharing options...
ronin_cse Posted May 20, 2015 Author Share Posted May 20, 2015 Yeah that is what I figured, oh well. I guess I can just build up my Ultras that I have and use them as stand ins for local games until I replace them with real HH Marines . On that note, are there any GW kits that are fine in 30k? Did the current Rhino pattern exist back then? What about the flyers? Edit: Also do I want to keep all my Tac Squads in the same mark of armor, or is that kind of my choice? Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051289 Share on other sites More sharing options...
Kol Saresk Posted May 20, 2015 Share Posted May 20, 2015 Rhinos yes. Flyers, not any sold by GW. Mark uniformity, that is up to your personal preference. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051302 Share on other sites More sharing options...
ronin_cse Posted May 20, 2015 Author Share Posted May 20, 2015 Rhinos yes. Flyers, not any sold by GW. Mark uniformity, that is up to your personal preference. Anything based on the pattern included? Like predators, whirlwinds, razorbacks, etc...? I'm assuming Dreadnaughts and Land Raiders existed back then in their current form as well? Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051308 Share on other sites More sharing options...
Fire Golem Posted May 20, 2015 Share Posted May 20, 2015 Rhinos yes. Flyers, not any sold by GW. Mark uniformity, that is up to your personal preference. Anything based on the pattern included? Like predators, whirlwinds, razorbacks, etc...? I'm assuming Dreadnaughts and Land Raiders existed back then in their current form as well? Dreads and Land Raiders did but only the standard LR I believe, not the variants like the Crusader (someone correct me if I'm wrong). Razorbacks also didn't exist then either. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051375 Share on other sites More sharing options...
Atia Posted May 20, 2015 Share Posted May 20, 2015 Rhinos yes. Flyers, not any sold by GW. Mark uniformity, that is up to your personal preference. Anything based on the pattern included? Like predators, whirlwinds, razorbacks, etc...? I'm assuming Dreadnaughts and Land Raiders existed back then in their current form as well? Dreads and Land Raiders did but only the standard LR I believe, not the variants like the Crusader (someone correct me if I'm wrong). Razorbacks also didn't exist then either. yep^^ you can use the "normal" mars pattern land raider phobos, rhino, predator (just the autocannon though), drop pod, dreadnought, venerable dreadnought, whirlwind, vindicator. i used the hunter too (as a "count as" whirlwind hyperios ... that thing is ugly imo xD). oh, and you could use the new exclusive rhino primaris as count as damocles :P Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051378 Share on other sites More sharing options...
Slips Posted May 20, 2015 Share Posted May 20, 2015 Rhinos yes. Flyers, not any sold by GW. Mark uniformity, that is up to your personal preference. Anything based on the pattern included? Like predators, whirlwinds, razorbacks, etc...? I'm assuming Dreadnaughts and Land Raiders existed back then in their current form as well? Dreads and Land Raiders did but only the standard LR I believe, not the variants like the Crusader (someone correct me if I'm wrong). Razorbacks also didn't exist then either. No las predator Only the phobos/godhammer LR, no other variants iirc,besides the achilles and proteus. No storm raven, no storm talon No thunderfire cannon. Box dreads are ok in all variations; though there is no specific entry for Ironclads but, we have contemptors anyways which are infinitely better than Ironclads. No razorbacks. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051382 Share on other sites More sharing options...
ronin_cse Posted May 20, 2015 Author Share Posted May 20, 2015 Excellent! Thanks everyone! I haven't painted most of my vehicles yet since I got side tracked with other things so that actually gives me a decent base to build from, plus a have a vindicator laser destroyer on the way too. Now I just need to get Tempest so I can decide which Ultramarine units really appeal to me. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051387 Share on other sites More sharing options...
Skalpynock Posted May 20, 2015 Share Posted May 20, 2015 Indomitus-pattern Terminators (normal 40K ones) are perfectly fine, as long as you remove the Crux Terminator. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051408 Share on other sites More sharing options...
infyrana Posted May 20, 2015 Share Posted May 20, 2015 From your tactical box of plastic marines, you could remove the MkIV / V / VI parts from the box sets to create the odd HH marine, or mix those parts in with the HH specific stuff. This includes the studded shoulder pad, MkVI beaky helm, corvus legs and chest, MkV chest, and you could mix in a few of the choice bolters / weapons too. But you'd probably be served well if you removed many of the purity seals and most all of the skulls everywhere and avoid MkVII armour pieces. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4051517 Share on other sites More sharing options...
Reyner Posted May 21, 2015 Share Posted May 21, 2015 You could use Thunderfire cannons as quad launcher rapiers? Just swap the techmarine for 2 regular marines with pistols. Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4052149 Share on other sites More sharing options...
Atia Posted May 21, 2015 Share Posted May 21, 2015 You could use Thunderfire cannons as quad launcher rapiers? Just swap the techmarine for 2 regular marines with pistols. yep you can ... the thunderfire cannon is a quad launcher rapier xD Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4052173 Share on other sites More sharing options...
ronin_cse Posted May 21, 2015 Author Share Posted May 21, 2015 You could use Thunderfire cannons as quad launcher rapiers? Just swap the techmarine for 2 regular marines with pistols. yep you can ... the thunderfire cannon is a quad launcher rapier xD Of course the issue there is the damn thunderfire cannon is more expensive than the rapiers, and it's sucky fine cast instead of FW resin Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4052415 Share on other sites More sharing options...
Atia Posted May 21, 2015 Share Posted May 21, 2015 You could use Thunderfire cannons as quad launcher rapiers? Just swap the techmarine for 2 regular marines with pistols. yep you can ... the thunderfire cannon is a quad launcher rapier xD Of course the issue there is the damn thunderfire cannon is more expensive than the rapiers, and it's sucky fine cast instead of FW resin yep of course :P the forgeworld rapier looks thousand times better!! but ... if someone would have an old thunderfire cannon, he could use it as rapier :P Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4052418 Share on other sites More sharing options...
ronin_cse Posted May 21, 2015 Author Share Posted May 21, 2015 Well thanks for being an enabler everyone! Just ordered Tempest...guess I'm trapped now ;) Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4052998 Share on other sites More sharing options...
Slips Posted May 22, 2015 Share Posted May 22, 2015 Well thanks for being an enabler everyone! Just ordered Tempest...guess I'm trapped now Part of the ship...part of the crew... Link to comment https://bolterandchainsword.com/topic/307907-couple-questions-about-getting-started/#findComment-4053110 Share on other sites More sharing options...
