Joe Posted May 21, 2015 Share Posted May 21, 2015 Hey all. I have a rhino chassis from the Deimos Pattern Predator kit (the roof section) that is bent slightly out of alignment on one side, preventing the model from fitting together correctly. Does anyone have any idea how I might be able to bend it back into shape? Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/ Share on other sites More sharing options...
Quixus Posted May 21, 2015 Share Posted May 21, 2015 If the part is resin, put it in hot water and flatten it out. Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/#findComment-4052336 Share on other sites More sharing options...
Carlson793 Posted May 21, 2015 Share Posted May 21, 2015 To add to Quixus' recommend, put in hot water, and when the resin is pliable, pull it from the water, bend it to the shape it's supposed to be, and while still holding it in shape, plunge it into ice water until all the heat dissipates from the part. Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/#findComment-4052362 Share on other sites More sharing options...
Aias Posted May 21, 2015 Share Posted May 21, 2015 When I was working with that kit recently, I actually found a hair dryer on low heat worked wonders. Use the dryer in one hand, part in the other and you can get it to straighten quickly. If the dryer has a "cool" setting, you can then use that to cool it off quicker, as well. Just be careful not to use it for extended periods; this works best with minor warping rather than having to extensively reshape a part. Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/#findComment-4052383 Share on other sites More sharing options...
Joe Posted May 21, 2015 Author Share Posted May 21, 2015 It's not actually a resin piece that's causing any issues; oddly enough none of the resin pieces in the kit are warped for a change. :p It's the actual rhino hull that Games Workshop produce, which has bowed upward/outward, leaving a few mm gap whenever the kit is put together for a dry run. I'll try heating it up with a hairdryer and bending it that way. Cheers for the advice all. \o Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/#findComment-4052425 Share on other sites More sharing options...
Grotsmasha Posted May 24, 2015 Share Posted May 24, 2015 Liquid Green Stuff to gap fill is an alternative to sort the last little gap. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/307942-bending-a-rhino-chassis/#findComment-4056295 Share on other sites More sharing options...
