Just a question on the arm/elbow part. On my knight, both elbows are rather loose. This makes the arm swing a 360 everytime there is a little bit of movement to the knight. I could glue it, but that i can't swivel the gun/sword around anymore.
Does anybody have an idea how to fix it? i just want it a bit firmer, so that it stays in place unless i push it into a direction.
Cheers
Thanks for the answers!
Not sure if magnets will do it, or atleast, my magnets. The ones that are strong enough are also 2 big for my drill bits.
Can try the glue option, but will need to find my plastic glue for it. Otherwise i can try upsizing the joint a bit with green stuff.
I normally undercoat by airbrush, which is fairly thin in it's application :(
Register a new account
Sign in
