Forté Posted May 26, 2015 Share Posted May 26, 2015 I need to add both to two Vindicators but can't stand the ones in the kits. -Dirge Caster: the GW one is too big and too intrusive. -Warpflame Gargoyles: I believe most would use the beast heads on the accessory spruce. Way too small for the Vindi cannon. So please, any ideas or things you've found. I'm in the UK too so please bare that in mind. Many, many thanks :tu: Link to comment Share on other sites More sharing options...
Plaguecaster Posted May 27, 2015 Share Posted May 27, 2015 For the warpflame gargoyles you could try bits from the vampire counts range they have a lot of flame bits especially the corpse cart which has a flaming skull cauldron as well lanterns and torches maybe try some of them, could have the cauldron directly above the main gun and torches or lanterns around the side of the vindicators don't know about dirge caster I usually use Nurglings or a lot of bells from the plague bearer kits or corpse cart though that probably may be more for Nurgle Link to comment Share on other sites More sharing options...
Forté Posted May 27, 2015 Author Share Posted May 27, 2015 I've ended up adding some flame coming from the skull on the top of the cannon and I'll paint some glowing runes on it too in the same colour as the flames (erm...that means I'm going to have to do a bit of osl...oh poop). And the little beast heads in the kit I've added above where the cannon is for the Dirge Casters. Should do it I reckon. Link to comment Share on other sites More sharing options...
Dragonlover Posted May 27, 2015 Share Posted May 27, 2015 I've got a Vindi where I swapped the cannon barrel for a head from the plastic dragon. At least, I'm pretty sure I did. That could work. Dragonlover Link to comment Share on other sites More sharing options...
Forté Posted May 27, 2015 Author Share Posted May 27, 2015 Maybe if I do a third one day ;) Link to comment Share on other sites More sharing options...
