GrandMasterAralia Posted May 27, 2015 Share Posted May 27, 2015 Just a quick question! Does any of you know where i can buy the small oval bases (the new ones from the skitarii set)? GW doesn't seem to have ten, and ebay wasn't helpful either... The bases are just the right size for prone Elysians :) Cheers! Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/ Share on other sites More sharing options...
Grotsmasha Posted May 27, 2015 Share Posted May 27, 2015 That base is 60mm x 35mm, most of Dragon Forge's base ranges have 70mm x 20mm 'bike' bases which should do the job nicely. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/#findComment-4060252 Share on other sites More sharing options...
GrandMasterAralia Posted May 27, 2015 Author Share Posted May 27, 2015 That's very helpful thank you! I'm just not a fan of that particular type of base. I tried putting my troops on the new gw bike bases and it don't look quite as good as on the oval base! But I might persuade my self because I'm going to do urban rubble for their bases and the dragon forge urban rubble look very nice :) thanks for the link! Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/#findComment-4060296 Share on other sites More sharing options...
CommodusXIII Posted June 2, 2015 Share Posted June 2, 2015 · Hidden by Grotsmasha, June 2, 2015 - Uhh, wut?? Hidden by Grotsmasha, June 2, 2015 - Uhh, wut?? Get the :cuss: out. Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/#findComment-4067805
CommodusXIII Posted June 2, 2015 Share Posted June 2, 2015 The oval base is the same as the Broodlord in the Deathstorm box set - maybe it will turn up somewhere?I have to apologize for an earlier post of mine here. Someone posted some very inappropriate spam and I, being half-asleep and in a foul mood, reacted inappropriately myself. It looks like some kind of filter or bot erased it before anyone could see it, leaving my comment with no context. It wasn't directed at anyone (now) in this thread! EDIT:I was wrong. The Broodlord is on a 75x45mm base. The Skitarii base is 55x32mm. Here are a couple bits sellers to keep an eye on: Bits and Kits bitzbox (picture is wrong, but I think the base is correct) Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/#findComment-4068256 Share on other sites More sharing options...
GrandMasterAralia Posted June 2, 2015 Author Share Posted June 2, 2015 Thanks for the help Again! I'll be sure to check out those bit sites, and maybe see if I can scrounge up a broodlord base to see I that one does the trick better! Link to comment https://bolterandchainsword.com/topic/308274-skitarii-sniper-bases/#findComment-4068938 Share on other sites More sharing options...
