marshall Egregorius Posted June 2, 2015 Share Posted June 2, 2015 So I accidentally applied ironearth to my onager dunecrawler's 100mm base without first basecoating it. due to the cracked pieces of the paint effect becoming unstable and breaking away from the base, i have elected to strip the panting effect and start over. However, i am unsure how to proceed due to needing this done asap, and scrubbing with warm water taking quite a bit longer than expected. simple green would take to long I suspect. anyone ever had to remove ironearth or the other crackle paint effects from bases? Link to comment https://bolterandchainsword.com/topic/308601-removing-martian-ironearth-from-base/ Share on other sites More sharing options...
Grotsmasha Posted June 2, 2015 Share Posted June 2, 2015 My advice is to use Lahmian Medium and seal it, re-prime/basecoat then do another coat of Martian Ironearth. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/308601-removing-martian-ironearth-from-base/#findComment-4067875 Share on other sites More sharing options...
