Ishagu Posted June 2, 2015 Share Posted June 2, 2015 I was wondering if there was a way to remove some resin heraldry pieces stuck to the doors of a few of my tanks without completely scraping and ruining the finish of the model? They were super-glued on pretty tight :-/ Link to comment https://bolterandchainsword.com/topic/308629-any-way-to-remove-some-resin-pieces-stuck-to-plastic/ Share on other sites More sharing options...
xera32 Posted June 2, 2015 Share Posted June 2, 2015 Repeatedly Freeze and defrost the model. Freezing super glue makes it brittle. You may still have to slightly damage the surface to get a pick or prybar behind the resin piece to break it off. Not garunteed, but it is the old way for dissasembling models. Link to comment https://bolterandchainsword.com/topic/308629-any-way-to-remove-some-resin-pieces-stuck-to-plastic/#findComment-4068466 Share on other sites More sharing options...
Larkyn Posted June 2, 2015 Share Posted June 2, 2015 In my experience, the best way to remove resin from plastic (or indeed, other resin) is just to drop it on the floor. Instant removal! In seriousness though, the freezing method is probably the best. Link to comment https://bolterandchainsword.com/topic/308629-any-way-to-remove-some-resin-pieces-stuck-to-plastic/#findComment-4068591 Share on other sites More sharing options...
