Alternative basecoat cans
In the UK, you can't go wrong with a visit to your local branch of halfords. Their white and grey primers are both cheap and excellent.
+1 They're cheaper, smell less when you use them, give a smoother finish and you need less.
I do still use GW ones though...
What I do, is I go to my local paintstore (5 minutes from my house). They have a large selection of spray paints, both matte and shiny and if I need a specific colour they will even create it by blending other colours together.
Currently my black and white primers are both from that store and both are for spray painting cars. Believe me, they are wonderful. So I highly recommend going to your local paint store first, just ask them if spray suitable for miniature painting. If they arent able to help you, then you can always go online.
PS: Its cheaper.
I can vouch for the black from Halfords.
That's good to know, I've not tried the black yet.
Halford black is a good colour but not a primer.
Autotek grey and white primer is also very good and can be ordered via amazon for those who cannot get to a Halfords
In the UK, you want Halfords sandabale primers - they are brilliant. Make sure you buy primer and not paint though.
Also, whilst using a primer in a tone or colour that's helpful to your main paint scheme, don't just work off the primer and leave parts of it showing as "finished", because it's not designed for that and will look pretty poor.
For example, if you're painting White Scars, then you are likely best off starting with a white or light grey primer - if you start off with a white, you still have to paint a few coats of white paint of the areas that will be white at the end. This is becuase the paint and primer are formulated differently and are designed to be used in combination, and using one without the other will lead to a poor finish.
Of course, if you don't mind the finish of bare primer, that's up to you! :P
