oxskull Posted June 17, 2015 Share Posted June 17, 2015 Hey all not sure if this is right place but quick query re different paints. I have always used the GW paints. But have recently discovered Revell paints in local toyshop. was just wondering if anyone has used them and what they thought of them. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/ Share on other sites More sharing options...
Lucien Eilam Posted June 17, 2015 Share Posted June 17, 2015 Which ones are you looking at? I used their enamels (in tins) years ago. They're very good as enamel goes, but that's a very different way of working to Citadel Colour. I haven't used their acrylics (Aqua range, the weird cubic pots). Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4091681 Share on other sites More sharing options...
Stoic Raptor Posted June 18, 2015 Share Posted June 18, 2015 I have never been fond of enamels - in my opinion, there are two types of people who use them: Beginners who'd truly be better off with acrylics until they master the proper techniques; and experts who don't need advice from lesser beings like myself. :) Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4091928 Share on other sites More sharing options...
Gurth Posted June 18, 2015 Share Posted June 18, 2015 If you’re talking about the blue, square plastic … bottles? jars? pots? containers then the paint is pretty good, but beware that the container suffers from similar problems as GW’s: the paint will dry out much faster than you’d like. From personal experience I can tell you that you can stir isopropanol into them to thin them back down, though. Also, if you buy them, check the label for instructions on how to open them: don’t try to pry the lid off, but twist it like ascrew cap. Beginners who'd truly be better off with acrylics until they master the proper techniquesExcept that techniques for painting with one don’t really apply to the other. Yes, they’re both paints that you apply with a brush, but due to differences in drying time and the way the paints react to solvents, you can do things with enamels that you can’t with acrylics, and vice-versa. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092039 Share on other sites More sharing options...
Guest Dwiopiued Posted June 18, 2015 Share Posted June 18, 2015 · Hidden by Grotsmasha, June 18, 2015 - spam Hidden by Grotsmasha, June 18, 2015 - spam monumental number and distributed to the people close to handing it parts to the clear-cut places, posting in the chic on and mailing during door to door marketing procedure. Leaflets are assuredly ulotki reklamowe accordingly when people chanced upon some needs of commodity or armed forces details they would fitting refer to that leaflets they have kept all along. People provide for the senses to suppress leaflets repayment for the sake future references and this is also what makes leaflets easier to pass on from personal irons Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092058
Stoic Raptor Posted June 18, 2015 Share Posted June 18, 2015 Perhaps, but beginners wouldn't know how to do those things. More accurate to say that some things are done more easily with one or the other - but techniques exist to do those tasks with both. Enamels simply aren't a good choice of paint for beginners. Learning to properly work with them is far less forgiving. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092502 Share on other sites More sharing options...
Gurth Posted June 18, 2015 Share Posted June 18, 2015 Perhaps that means they are more suitable for beginners. You tend to learn more from first doing something the hard way before you get to do it the easy way. Though I wouldn’t say enamels are harder to paint with than acrylics ±— just a bit different. OTOH, you could argue that my perception is coloured by having used enamel paints from age 7 before first coming across acrylics at about twice that age Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092542 Share on other sites More sharing options...
Stoic Raptor Posted June 18, 2015 Share Posted June 18, 2015 If part of the learning process involves ruining expensive models, then I'd agree. I have yet to see a beginner produce good results with enamels. I was 13 when I started painting - that was 35 years ago and enamels were pretty much the choice due to their wide availability. Fortunately, no evidence of my work remains. When I discovered acrylics years later, my results began to improve significantly. GW's methods allow an inexperienced painter to produce some good tabletop results, whereas with enamels, shading and highlighting are a more advanced technique. Drybrushing is not as easy, and while blending might be simpler to do, it's a lot messier and probably not within a new painter's skillset. Your mileage may vary - someone with years of experience painting with enamels may disagree with my assessment, but if they have all that experience, they're reinforcing my belief that it's a medium best employed by experienced painters. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092567 Share on other sites More sharing options...
Lucien Eilam Posted June 18, 2015 Share Posted June 18, 2015 As fascinating as this debate is, I just asked which ones he'd been looking at. Revell do have an acrylic range too. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092740 Share on other sites More sharing options...
Daevyll Posted June 18, 2015 Share Posted June 18, 2015 My experience with the Revell acrylics is that they are not as good as Vallejo or P3 but not terrible for minis like for example Talens either. I'd buy them if they were the only ones readily available, but if Citadel is available too I'd stick with that personally. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4092908 Share on other sites More sharing options...
Gurth Posted June 19, 2015 Share Posted June 19, 2015 If part of the learning process involves ruining expensive models, then I'd agree.Heh … as if nobody’s ever ruined a model by painting it with acrylics. I have yet to see a beginner produce good results with enamels.I have yet to see a beginner produce good results, period. Everybody starts off “block-painting” models, and for that it doesn’t matter what paint you use. I maintain that enamels or acrylics doesn’t matter when you’re starting from scratch — it’s not like we’re talking about oil paints here. that was 35 years agoSo about as long as for me, then. Drybrushing is not as easyWith enamels? I beg to differ … I find there’s quite a lot of variation in acrylics when it comes to drybrushing (GW’s drybrush well for example, but some Tamiya colours are just about impossible to drybrush with) while I’ve never seen an enamel paint that gives any trouble at all, especially if you use the old Verlinden method of not stirring the paint but going straight for the pigment. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4093352 Share on other sites More sharing options...
Bartali Posted June 19, 2015 Share Posted June 19, 2015 @Gurth - Tamiya acrylics are an altogether different beast altogether though. Alcohol based rather than water based like GW/Vallejo etc I'm sure hand brushing is technically feasible with Tamiya acrylics, but it's not something I like to do. I keep them just for airbrushing, and they're my favourite paint range for running through an airbrush Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4093377 Share on other sites More sharing options...
Gurth Posted June 19, 2015 Share Posted June 19, 2015 I like Tamiya for brush-painting, but they have a tendency to get problematic if the jar was first opened a long time ago — paint lifting off if you brush over it again before it’s fully hardened, for example. Drybrushing is really strange because it works well with some colours but not at all with others. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4093922 Share on other sites More sharing options...
oxskull Posted June 19, 2015 Author Share Posted June 19, 2015 they are the enamel ones in tin pot. tried them but dont really like them so think i'll stick with GW ones. was just looking a cheaper alternative. and these were only ones available locally. Link to comment https://bolterandchainsword.com/topic/309531-revell-paints/#findComment-4094178 Share on other sites More sharing options...
