Ushtarador Posted June 18, 2015 Share Posted June 18, 2015 Hey guys! I'd like to build a small diorama for a painting competition that involves a kneeling marine praying to the emperor or something. The pose I have in mind is quite generic, something like this: http://vignette4.wikia.nocookie.net/warhammer40k/images/d/d3/Uriel_Ventris_Praying.jpg Does anyone have an idea how I could realise the arms without too much modelling? Even 1 arm resting on the sword would already be good enough I think. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/ Share on other sites More sharing options...
paulJam Posted June 18, 2015 Share Posted June 18, 2015 Too much modelling... There are plenty of 90 degree 'bent arm' bits. Try pistol arms especially. Cut off the pistol hand at the wrist. Glue on an empty hand (sergeant pointing etc). Can't mention any sprue in particular. Empty shooty hands from tac marines for weapon of choice. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4092851 Share on other sites More sharing options...
Stercus Posted June 18, 2015 Share Posted June 18, 2015 The arms from the vehicle accessories sprue would be my first port of call for this job. Once you trim off the storm bolter grip, they are useful for any conversion where the arms need to come across the body. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4092858 Share on other sites More sharing options...
Father Mehman Posted June 18, 2015 Share Posted June 18, 2015 The Space Marine Sternguard Veteran Squad box has a bit with a hand resting on the pommel of a power sword. Using that bit, maybe an arm from a vehicle accessory sprue, like Stercus mentioned, and some Green Stuff and you're all set to go ! Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4092898 Share on other sites More sharing options...
Durus Posted June 18, 2015 Share Posted June 18, 2015 Inquisitor Karamazov, one of the chapter masters (guy with powersword and powerfist holding his helmet) and the Dark Angels Termie kit have a sword with at least one arm on the handle of their sword. Not sure of comfortable you are with sculpting but since the fingers lay flat on something sculpting the hands would essentially boil down to putting the putty on the handle, flatten it to the right thickness, cut a rectangular shape, taking off the excess and scoring the individual fingers into the GS. Failing that I'd use something like the arm of a standard bearer and just cut the staff so you can use it as handle for whatever weapon you want to use. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4092899 Share on other sites More sharing options...
Ushtarador Posted June 20, 2015 Author Share Posted June 20, 2015 Thanks for all the ideas, that's all very helpful :) I'm ok with modelling simple things, but I still prefer to avoid it if possible :P fingers should be fine though. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4094650 Share on other sites More sharing options...
Acebaur Posted June 20, 2015 Share Posted June 20, 2015 There's also this guy http://www.reapermini.com/graphics/gallery/4/02906_G.jpg I have that mini and his hands and sword are a separate piece. I can check scale if you like, but I remember him being pretty close to marine size. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4094798 Share on other sites More sharing options...
GhostLegion Posted June 20, 2015 Share Posted June 20, 2015 ive had good results on this type of pose using a tight angle right arm/hand with pistol/bolter and a left arm/hand for holding a bolter. trimming away the pistol/bolter and a bit of adjustment for both wrists and you can get pretty close to that pose. at least convincingly close. add in the kneeling legs from the dev sprue and youre right there with a kneeling marine. for the sword, well, any sword will work into this method, just need to trim the pommel and blade from around the hand, then reglue to the new posed piece (but that much is obvious). one thing i can recomend is to experiment with the strict 90 degree right arm and one that is slightly more than 90. sometimes the slightly more open works better....the last one i did like this i also had to cut just above the elbow on the right arm to turn the forearm slightly more into the chest space...thus making the wider angle at the elbow more useful as it gave more room to center on the chest/head for the pose. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4094907 Share on other sites More sharing options...
phoenix01 Posted June 20, 2015 Share Posted June 20, 2015 The new Devestator sprue has both a left and a right open hand that might work for holding the sword. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4094909 Share on other sites More sharing options...
paulJam Posted June 24, 2015 Share Posted June 24, 2015 brother @ShVagYer has a dark angels version like the one in your picture. first post in this thread, one of the last pics... http://www.bolterandchainsword.com/topic/293731-lodzkie-manufactorum/ ...for inspiration if not bitz help. Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4101345 Share on other sites More sharing options...
ShVagYeR Posted June 25, 2015 Share Posted June 25, 2015 brother @ShVagYer has a dark angels version like the one in your picture. first post in this thread, one of the last pics... http://www.bolterandchainsword.com/topic/293731-lodzkie-manufactorum/ ...for inspiration if not bitz help. Thanks for noticing! I used a vehicle gunner arm. No greenstuff was used on this mini. :) Link to comment https://bolterandchainsword.com/topic/309602-arms-resting-on-sword/#findComment-4102112 Share on other sites More sharing options...
