Is there a place to buy Turrets for Leman Russes?
Bought the Cadian Defense Force Box, three of them.  On the box it just said "1 Leman Russ Tank".  Found out you can only make 4 variants of the Leman Russ with this box.  I am trying to magnetize my Lemans to be able to support any configuration.  Apart from Ebay which is kind of hit or miss, are there any good websites for buying Leman Russ turrets?  Cannons? Specifically the 3 variants that you can't make from the Cadian Defense Box.  The ones you can make are Battle Cannon, Vanquisher Battle Cannon, Eradicator Nova Cannon, Exterminator AutoCannon.  Need to try and find the Punisher Cannon, Executioner Plasma Cannon and Demolisher Cannon.
Forgeworld sells some (all?) of the turrets, but they’re of a slightly different design in case you want to… eh.. have a coheisiveness when aesthetics are concerned if you later buy the other leman russ kit.
There’s always bitz sellers of course :)
Depending on how many tanks you envision for the future, it might just be an easier (possibly cheaper too) to just buy more leman russes. Magnetise each variant with cannons that come in the box and leave it at that. I’ve got 3 from defence forces as well, but can’t envision an army where I wouldn’t be needing more than three regardless, so I can just grab a few of the other box.
The turret cannon mounts aren't the same between the two Russ kits, but the turret ring is so you can swap turrets ok. As Emicus says magnetising it always a good idea especially for the Demolisher kit where it is criminally easy :)
you can! provided you don' glue on the gun manlet but magnetize/pin it to the turret and leave the the base of the turret unattached. the B&C tutorial suggest you glue on the gun mantlet but this prevents it to include the demolisher variants
I'm looking for Russ turrets as well, so I can work on some custom variants, (the Avenger with the Avenger Bolt Cannon, and the Eviscerator with a Triple-Barreled Multi-Laser.) Neither of these are canon, but who the heck cares, eh? :P
