Scimitar jetbikes
thor1234
Iirc, arms are separate from the body but the torso, legs and head are one piece.
This is true, but they grey knight kit terminator kits has a bunch of apothecary bits in it that you can throw on then just use the MK4 arms that come with the Apothecary.
Pretty sure GK apoth bits are termy sized.. So that means you arent really going to use the arm.
I think the Ravenwing Command Squad set has some nice Apothecary bits for a bike-mounted model.
The Narthecium arm is posed to fit on a biker model, so it will fit on a Jetbike without modification. The RW Apothecary torso also looks a bit like Mk IV armour, and there's some Apothecary equipment bits that can be attached to the (jet)bike.
I made this Librarian on Jetbike conversion for one of Grotsmasha's kitbash events:
One very belated kit bash for the Librarian Conversion Challenge. Provided I get that far, this and a squad of bikes are penciled in for my third ETL vow.
Front:
Left side:
Rear:
Right side:
Angle:
Parts used:
  • Legion Scimitar Pattern Jetbike
  • Heavy flamer from the second edition Predator Annihilator kit
  • Space Marine Bike legs and left arm
  • Blood Angels Death Company shoulder pad
  • Second edition Character arm should pad
  • Staff and torso from the Grey Knights box
  • Tactical box right arm
  • Head from the Grey Knights Terminator box
Basically, the torso back needed the backpack bump filing off and there's a slight bit of tweaking needed on the pose as the space marine bike parts are a little longer than the jetbike bits. It's also worth noticing that the legs on the SM bike are a different shape from that of a jebike so it doesn't fit as well.
Not the apothecary arm but everything else works fine. The vials and back pack lamp work.
