Barabbas Sogalon Posted June 22, 2015 Share Posted June 22, 2015 Just something I need cleared up before bloodletting my wallet. 1. What parts are Sevatar made up of? Most importantly are his arms fully separate pieces? 2. Is it possible to give the Polux model a helmet or is it necessary to remove the gorget first? 3. Out of curiosity: Is Polux (only the man himself) larger than other marines? Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/ Share on other sites More sharing options...
Toomanyprojects Posted June 22, 2015 Share Posted June 22, 2015 Don't know about 1&2 but Pollux is definitely large than a normal marine. The fluff says that he is a huge guy and towers above his subordinates. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4097988 Share on other sites More sharing options...
m_r_parker Posted June 22, 2015 Share Posted June 22, 2015 Can't help on Sev, but if he's like most of the other Character series he's most likely to be single torso / legs, separate arms and pads and a separate head. I've just tried to put a Mk IV head in the Pollux that I have (he's unassembled at the moment, and MkIV is the most 'discrete' helm to put on), and the gorget does indeed get in the way. Either he goes bare headed or you cut the gorget away. As for the size of Pollux, he's a big boy. He's more or less the same height as a Character in Terminator Armour. I took the below a couple of months ago (when I got back from the Weekender) and compares the height with Abaddon (in Termie Armour) and the two Imperial Fist Command Squad members. If you look in the gorget and the lines of the pad behind the models, you can see he's in line with Abaddon and taller than the Command Squad. http://i162.photobucket.com/albums/t272/m_r_parker/Heresey%20Weekender%202015/6ED5C26C-565A-48D5-9237-486CBF520DF9_zpskvlfwhfh.jpg Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4098003 Share on other sites More sharing options...
1ncarnadine Posted June 22, 2015 Share Posted June 22, 2015 1) Nope, large portions of the arms are part of the torso unfortunately. The right hand is separate, and the left forearm is separate. Here, jacked this pic from ebay to illustrate: http://i.imgur.com/m9PFESX.jpg?2 Not sure on 2 & 3. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4098010 Share on other sites More sharing options...
Barabbas Sogalon Posted June 22, 2015 Author Share Posted June 22, 2015 @ m_r_parker: Had planned to use a mk III helm, so I guess that means no gorget. Good to know about the size. He'll do well as a giant Iron Warrior. @ LetsYouDown: I feared that was the case. Hopefully it won't be too difficult to remove the arms without collateral damage. Thanks, guys. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4098105 Share on other sites More sharing options...
Daemon2027 Posted June 23, 2015 Share Posted June 23, 2015 Just to add its really hard to get a helm on Pollux. I tried to get Khâtns helm on which is a little smaller and found it hard. I also struggled with the bare head from the Praetor set. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4099491 Share on other sites More sharing options...
Slips Posted June 23, 2015 Share Posted June 23, 2015 Just to add its really hard to get a helm on Pollux. I tried to get Khâtns helm on which is a little smaller and found it hard. I also struggled with the bare head from the Praetor set. To add: The socket for Polux's head isn't like most others. It and the connector part of his head are both kinda oval so that when you pop it in it faces a certain direction. You'd probably have to carve a bit out of it to widen the gap and make it rounder to have an easier time fitting other heads. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4099625 Share on other sites More sharing options...
Barabbas Sogalon Posted June 23, 2015 Author Share Posted June 23, 2015 Can't say I'm happy to hear that, but I'll do what it takes to get my Iron Warrior captain. Link to comment https://bolterandchainsword.com/topic/309844-about-the-sevatar-and-polux-models/#findComment-4099726 Share on other sites More sharing options...
