demio Posted June 27, 2015 Share Posted June 27, 2015 So I'm about to order him and want to give him a helmet. I will probably have to sculpt it as he's so huge compared to other marines a simple swap probably won't work. Has anyone seen any artwork of him with a helmet? And if yes can you link or point me in the right direction please. I would assume it's going to be like the Breacher Marines helmets. Cheers all! Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/ Share on other sites More sharing options...
m_r_parker Posted June 27, 2015 Share Posted June 27, 2015 There's been a couple of threads about similar stuff already. The Gorget of his armour makes a helmet impossible to put on - and some people have found that other bare heads also have problems fitting. Proceed with care. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105003 Share on other sites More sharing options...
Lucien Eilam Posted June 27, 2015 Share Posted June 27, 2015 He wears a Mk III helm, to match his artificer Mk III armour. From The Crimson Fist: "I nodded, locked my plough-fronted iron helm in place, and opened a communication channel." So you could try a breacher helm, or maybe the laureled helm from the IF head upgrade kit. As you say, he's massive, so he might look a bit pin-headed with a standard helmet. Personally, I'd probably at least try it before breaking out the green stuff though. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105009 Share on other sites More sharing options...
Sothalor Posted June 27, 2015 Share Posted June 27, 2015 http://www.blacklibrary.com/Images/Product/DefaultBL/xlarge/shadows-of-treachery.jpg Isn't that supposed to be Polux front and center? Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105014 Share on other sites More sharing options...
Operative Posted June 27, 2015 Share Posted June 27, 2015 http://www.blacklibrary.com/Images/Product/DefaultBL/xlarge/shadows-of-treachery.jpg Isn't that supposed to be Polux front and center? Yes it is, you can tell he is wielding his power fist too Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105017 Share on other sites More sharing options...
demio Posted June 27, 2015 Author Share Posted June 27, 2015 You guys are gents! I'll work something out and you can all laugh at my failures! Cheers Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105037 Share on other sites More sharing options...
Thorv88 Posted June 27, 2015 Share Posted June 27, 2015 Mine had a laurelled helmet from the IF upgrade spu but if I remember correctly I but a small dob of grernstuff under to raise it up a mm Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105161 Share on other sites More sharing options...
demio Posted June 27, 2015 Author Share Posted June 27, 2015 Thorv88 I have that exact helm. How does the scale look with it on? Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105220 Share on other sites More sharing options...
Thorv88 Posted June 27, 2015 Share Posted June 27, 2015 Looks fine. The scale is in your mind. Just raise it up a little and he looks spot on. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105411 Share on other sites More sharing options...
demio Posted June 27, 2015 Author Share Posted June 27, 2015 Awesome. Cheers. I have 2 of them as I was going to use one for Sigismund aswell. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105440 Share on other sites More sharing options...
Thorv88 Posted June 27, 2015 Share Posted June 27, 2015 Not a bad shout. And make it black. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105479 Share on other sites More sharing options...
lionofjudah Posted June 27, 2015 Share Posted June 27, 2015 I'll try the laureled helm as well- don't like my marines to be bareheaded- doesn't make much sense to me:) Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105667 Share on other sites More sharing options...
Marshal Rohr Posted June 28, 2015 Share Posted June 28, 2015 Shave the gorget down. The helms scale fine. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105821 Share on other sites More sharing options...
Corswain Posted June 28, 2015 Share Posted June 28, 2015 If your unhappy with scale maybe use a Grey Knights Terminator helmet? It's knighty enough! Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4105920 Share on other sites More sharing options...
Gab Posted July 4, 2015 Share Posted July 4, 2015 Has anyone worked in some blue and Crimson for Polux? Curious as to how it looks and how others have worked it in. Link to comment https://bolterandchainsword.com/topic/310177-alexis-polux-helmet/#findComment-4112969 Share on other sites More sharing options...
