Mr. Surfacer 1500, laquer and airbrushing
Hi guys, in need of some help from you once more....
I have recently been having issues with my primer not griping enough to my resin and so decided to change over to Mr,surficer 1500
I plan on running it through my airbrush along with the Mr.color levelling thinner to give a nice smooth coat
Now up until now, I have only used acrylics through my airbrush so just after some advice before I screw everything up!
1. Do I need to do any prep to the resin aside the usual scrub and clean?
2. Do I need to do any prep to the airbrush aside from clean it?
3. What should I use to clean my airbrush with afterwards?
4. Should I change my psi?
5. How dangerous is it compared to acrylic and will my normal ventilation (respirator, spray box leading out of window, door open, window open) surfice?
6. Is it advisable to cover the whole model in an acrylic afterwards before building up my highlights?
7. Lastly, if I plan to use an oil wash later on after the highlights, will this effect the laquar primer underneath?
Sorry for all the q's but searching the internet I can't quite find all the answers I am looking for and I really don't want to mess it up!
Also, I have had a separate thread on my issues with current primer so not looking for advice on that and why that might now be working.
Many thanks!
