How do you base buildings?
Happen to have a Manufactorum and a Shrine of the Aquila unbuilt. Figure it would be best if I gave them bases. Not just for the added cover save I've seen been argued for, but for making the damn model itself more resilient. Now, what materials etc would you recommend I use?
https://bolterandchainsword.com/topic/310509-how-do-you-base-buildings/
Hardboard or thin MDF work well, corrugated cardboard also does the job but less well. If you go for cardboard, I suggest finding a strong box with a double layer of corrugations instead of just one, as this will prevent warping, and to use filler to close the edges — having the corrugations on display just looks bad. You can cut cardboard with a hobby knife, hardboard with a carpet knife or a saw (I’d recommend the latter), and MDF requires a saw.
Also what do you mean extra cover save? Ruins is ruins right?
Not entirely sure myself, I think I saw the argument made somewhere that if a ruin had a base, you got +1 cover save. Possibly wrong.
Anyhow, can I use the plastic glue with an MDF base or do I need something else, like superglue?
You can use PVA glue too. It just takes a while to set, so be patient. Superglue is probs best for stuff that will fall apart while drying. Then PVA after for a secure bond. smile.png
Heres some Shacks i made, glued to thin MDF. Work pretty well.
11109517_10153875716739498_2245456375997
11178298_10153875716559498_2047879738508
edit : A hot glue gun might be a smart buy if you're making a lot of terrain. They're really cheap nowadays, and pretty useful.
I found some thin MDF and made rectangular bases for my buildings with it (turns out I had a Basilica Administratum too!). Used super glue. Will likely spray coat it all in some shade of gray, paint details in gold and metal and whatever, paint the base to match the gaming table, call it a day.
Thanks guys!
EDIT: That ork prison is awesome MagicMan!!
