Quick Question - Can Macharius Tank turrets be swapped?
If there are any Macharius owners out there, can they chime in? I'd just like to know if the Macharius Heavy Tank's turrets can be swapped out easily. For instance, simply removing the Vulcan Turret and trading it for a Vanquisher turret without any magnets, like you'd do with Leman Russ or Predator turrets. At a glance, it looks like they can be, but I'd love for Macharius owners to chime in!
Do you mean the turret as in the entire thing, or just the weapon mounts? Coffee should be able to answer this at the least either way smile.png
The entire turret. As in, I'd like to know if I can just twist and pop the turret off in the manner of Leman Russ tanks and stick another different turret on it. A part of me is considering 2 Macharius' with slightly different themes and swap turrets to play with the visuals a bit. And also, bring two turrets and one hull to game nights for easy swapping and less space taken up.
Oh goodie. It's just one of the ideas I'm kicking around my head. The other one is a Land Raider Ares with hurricane bolter sponsons and some kind of CROWS weapon system made of Anvilus Autocannons on the roof. So many fun ideas to kick around. Thanks for the input, all! I just want to play with big tanks.
