Wulf Vengis Posted July 12, 2015 Share Posted July 12, 2015 Had anyone used this and if so what kind of review would you give of it with three different materials we generally work with in this hobby? Link to comment https://bolterandchainsword.com/topic/311036-e6000-glue/ Share on other sites More sharing options...
Ironwulf Posted July 12, 2015 Share Posted July 12, 2015 I've only used E6000 with a couple other craft projects, and I found that it's too "rubbery" to be used for modeling purposes. If assembling models with it, I think you're going to be very disappointed with it. There is ONE use that I would consider experimenting with it-- dripping saliva from a creature's mouth. Even so, I'd mess with it a bit beforehand, just to make certain that it LOOKED like that creature was drooling, and that I could get the effect I was going for. Link to comment https://bolterandchainsword.com/topic/311036-e6000-glue/#findComment-4121234 Share on other sites More sharing options...
Wulf Vengis Posted July 12, 2015 Author Share Posted July 12, 2015 Good to know Ironwulf, thank you. I'll steer clear of it unless i need to do some slavering beats aka thunder wolves. Link to comment https://bolterandchainsword.com/topic/311036-e6000-glue/#findComment-4121448 Share on other sites More sharing options...
Guest yarickkl Posted July 13, 2015 Share Posted July 13, 2015 How do you apply said glue? Do you use pretty much like the tube glue or is there some other method of using it? Link to comment https://bolterandchainsword.com/topic/311036-e6000-glue/#findComment-4122610 Share on other sites More sharing options...
CommodusXIII Posted July 22, 2015 Share Posted July 22, 2015 The consistency is somewhere between thick plastic glue and hot glue off the tap. I only use it for very large parts or terrain features where the gooiness is not an issue. Link to comment https://bolterandchainsword.com/topic/311036-e6000-glue/#findComment-4125616 Share on other sites More sharing options...
