++Daemon Forge: VII - Daemons theme++
Welcome to - Daemon Forge -
- Daemon Forge - is aimed as a hobby challenge. Each month will see a set theme for Chaos. This will range from a set unit type, single models, object marker & set themes. The aim is pretty simple. It's all about seeing cool models for Chaos.
For the fourth - Daemon Forge - hobby challenge topic, this month challenge will be - Daemons -.
For this, all you need to do is enter a model, unit or tank that has the Daemonic rule from:
  • Codex Chaos Space Marines along with supplament: Black Legion, Crimson Slaughter & Daemonkin
  • Codex Daemons
  • Armour 13: Lost & the Damned
  • Chaos Knight with Marks (class the Knight as a Daemon)
As long as it has the Daemon rule.
To enter & for more detail please check out the main Daemon Forge topic which you can find here
http://www.bolterandchainsword.com/topic/311773-daemon-forge-vii-daemons-theme/
Thanks
https://bolterandchainsword.com/topic/311775-daemon-forge-vii-daemons-theme/
