Fluff: Are Plasmas an expensive commodity?
Are Plasma-based weapons expensive to produce? Do Regiments get them en-mass or are they are rare commodity? I was thinking to make my Regiment heat-weapon based. We are talking a good amount of Meltas spread here or there but mostly Plasmas up the rear. We are talking everything from the regular Plasma Guns in a Platoon and up to the Executioner being the main Battle Tank and even fully operational Stormblades (the one with the big Plasma Gun on it). As I gathered correctly, Ryza is the main expert on Plasma-based tech, right after Mars, correct?
Cheers ;)
I am not sure about the regular Plasmas, but Executioners and Stormblades seem to be made exclusively on Ryza (and Mars), so there can not be that many of them.
As of M41, the Leman Russ Executioner is only produced on Ryza. I think the Stormblade is produced in other Forge Worlds though.
I like to think of Executioners as relic vehicles personally. I always imagined them to be a maximum of one or two per armoured regiment, with the notable exception of Ryza's Skitarii regiments, who are known to have entire companies of them.
Do you want to be able to maintain them without Ryza? If the answer is "yes" then you can ;) Maybe some Ryza Enginseers accompany you, or they taught others how to look after the tanks? Building something is quite different to maintaining it, so I wouldn't worry too much about the fluff here.
Sweet. As a Knight House, they have relations with the AdMech, but Ryza is fairly far from where I want to locate myself. Hence the concern.
Also, how do you determine the colour of Plasma? Is it always that light blue (or red if you wear spikes and are evil) or can you add different flavours? I would like mine to be banana flavoured (read, yellow), like the Emperor's holy fire.
I keep hearing about how plasma weapons are supposed to be rare, but I don't think that fluff is up-to-date anymore. It seems like everyone and their pet grox has a plasma gun hidden somewhere these days!
As far as I know, the only "rare" plasma weapon is the Executioner, which is supposedly produced only on Ryza, but considering that the Ryza Stormblade is being manufactured on other worlds, I wonder if the Executioner is also being produced on other forge worlds such as Mars. It'd explain the discrepancy between the Executioner's main turret and the Ryza-pattern one FW makes, at least.
About colours - the colour of the plasma depends on the gas being used to create it and the temperature. Lightning, for example, is a plasma that sometimes appears yellowish-pale. I'm sure you can find a way to make your plasma emit a fiery colour, if you get the temperature right msn-wink.gif
Pick a colour that contrasts your main colour scheme nicely. Hence why I use Blue Plasma, though any colour is fair enough. Arguably Purple is the most accurate as the radiation would lean towards Ultraviolet and other high-frequency emissions.
I read that the colour of Plasma depends on temperature and gas. In the upper atmosphere, lightning has a different colour than what we see. Orange and yellow is amongst them. What I read on a physics site anyway, take that for what you will.
Edit: Apparently, those electric discharges are called Sprites and happen above Thunderstorms.
I have not read any books yet (but i just got "First and Only" in the mail cool.png) BUT, from what I understand from my local group, plasma weapons are from the "Dark Age" of technology, so they 'get hot' because no one really know how to properly care for them. Do I have that right?
As to their rarity, I have no idea. They are quite rare for me, however, since they only come on the command sprues tongue.png
