Jofus Posted August 24, 2015 Share Posted August 24, 2015 I am trying to stick the plastic Herald of Khorne, from the blood throne, onto a 32 mm base but need some help overcoming his awkward leg stance. I am not very strong on modeling skills other than assembly so repositioning one of the legs is probably out. So what I am really looking for I think is something that he can have his leg propped up on. Does anyone have some suggestions? Link to comment https://bolterandchainsword.com/topic/312817-herald-of-khorne-help/ Share on other sites More sharing options...
Peredyne Posted August 24, 2015 Share Posted August 24, 2015 Looking at the Herald, I would think that's going to need at least a 40mm base. Barring that, I would probably go with layers of cork built up and overlapping to get the Herald to fit properly on a 32mm base. Link to comment https://bolterandchainsword.com/topic/312817-herald-of-khorne-help/#findComment-4154845 Share on other sites More sharing options...
Jofus Posted August 25, 2015 Author Share Posted August 25, 2015 I think I came up with a somewhat creative solution for him. I would probably have gone with cork layers but I am using the Secret Weapon Miniatures Bone Field bases for my Khorne Daemonkin army and would like to keep the theme as much as possible. Here is a quick pic I took of him blue tacked together with a bit of sprue on the base coming out as a support. http://i1014.photobucket.com/albums/af261/jofus2004/Khorne%20Daemonkin/IMAG0144.jpg I ended up attaching the sprue with some greenstuff to the base and then added some skulls and a chest from the old skeleton kit to decorate it some. I will also probably remove the chain in his off hand because I don't think I can add anything to it that would look natural in that pose. I might add some spikes or other bits to the piece of sprue to make it look more natural. Link to comment https://bolterandchainsword.com/topic/312817-herald-of-khorne-help/#findComment-4155379 Share on other sites More sharing options...
Warsmith Uveron Posted September 1, 2015 Share Posted September 1, 2015 I know this is an Old Post. But, I used the Stone Base from the Chaos Terminator Lord. (Best Picture I have is below) Though your solution looks good. Link to comment https://bolterandchainsword.com/topic/312817-herald-of-khorne-help/#findComment-4160988 Share on other sites More sharing options...
