GodEmperorOfMankind Posted August 29, 2015 Share Posted August 29, 2015 Hi all I have a forge world hydra flakk platform I just won and I want to take it apart as its been assembled poorly. However the glue has formed a solid bond (seems like generic superglue rather than epoxy two part glue) and I'm at a loss as to how I take it apart without breaking the resin. Any ideas would be much appreciated Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/ Share on other sites More sharing options...
klisof Posted August 29, 2015 Share Posted August 29, 2015 Put it in the freezer overnight, superglue becomes brittle when cold enough. You should be able to start separating model parts then as long as you are careful. I've not had to do this with anything bigger than a terminator but it worked very well for them. Good luck! Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4158608 Share on other sites More sharing options...
GodEmperorOfMankind Posted August 29, 2015 Author Share Posted August 29, 2015 Will the resin not also become brittle at low temps? Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4158684 Share on other sites More sharing options...
Grotsmasha Posted August 29, 2015 Share Posted August 29, 2015 A little, try to wedge from in the gaps rather than pulling on pieces. Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4158688 Share on other sites More sharing options...
SW1 Posted August 29, 2015 Share Posted August 29, 2015 I've used the freezer trick to take apart resin that's been well superglued together. A wedge in the joint an a light tap with a hammer and it popped apart. I'd use a pin hammer on something so small rather than a normal household hammer. Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4158744 Share on other sites More sharing options...
GodEmperorOfMankind Posted August 29, 2015 Author Share Posted August 29, 2015 Cheers for the tips guys. Will try it in the morning Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4158916 Share on other sites More sharing options...
Gurth Posted August 30, 2015 Share Posted August 30, 2015 Whatever you do, you’d probably best stay away from solvents. Acetone, for example, is often recommended because it will dissolve superglue, but it has the slight problem that it dissolves polyurethane resin too — which people who recommend acetone will usually not know about. If you do need to try a solvent, first put some scrap resin (preferably a piece of sprue from the actual kit) in it overnight to make sure it won’t affect that. Link to comment https://bolterandchainsword.com/topic/313003-ungluing-resin/#findComment-4159147 Share on other sites More sharing options...
