Aeternus Posted August 30, 2015 Share Posted August 30, 2015 A friend is now cutting up a fellblade for a few conversions, however one part he doesn't want is the turret (for some reason). Either I buy it or he puta it up for sale in our flgs, so I come to you with a query. Does the Fellblade turret fit on the glaive chassis, ie, is the size of the turret for each tank the same size, and do they both have the same chassis? Link to comment https://bolterandchainsword.com/topic/313062-fellblade-glaive-turret-compatibility/ Share on other sites More sharing options...
Olis Posted August 30, 2015 Share Posted August 30, 2015 I am under the impression both turrets are the same basic design. I can't confirm that though as I don't own both. Link to comment https://bolterandchainsword.com/topic/313062-fellblade-glaive-turret-compatibility/#findComment-4159622 Share on other sites More sharing options...
CommodusXIII Posted September 6, 2015 Share Posted September 6, 2015 As far as I know, the Fellblade and Glaive are variants of the same chassis. The turret should be the only major difference between the kits. Link to comment https://bolterandchainsword.com/topic/313062-fellblade-glaive-turret-compatibility/#findComment-4164884 Share on other sites More sharing options...
Slips Posted September 6, 2015 Share Posted September 6, 2015 For the most part, it should be easy enough. Just dont forget that a Glaive, unlike the Fellblade does not have a Demolisher Cannon. Hidden Content http://www.forgeworld.co.uk/resources/catalog/product/600x620/99590101326_LEGIONGLAIVE3.jpg http://www.forgeworld.co.uk/resources/catalog/product/600x620/99590101326_LEGIONGLAIVE2.jpg http://www.forgeworld.co.uk/resources/catalog/product/600x620/99590101326_LEGIONGLAIVE5.jpg http://www.forgeworld.co.uk/resources/catalog/product/600x620/99590101283_SPACEMARINEFELLBLADE5.jpg http://www.forgeworld.co.uk/resources/catalog/product/600x620/99590101283_SPACEMARINEFELLBLADE2.jpg The main differences, besides the barrels are the Rear Sections of the actual turrets. Link to comment https://bolterandchainsword.com/topic/313062-fellblade-glaive-turret-compatibility/#findComment-4164898 Share on other sites More sharing options...
Marshal Reinhard Posted September 6, 2015 Share Posted September 6, 2015 The fellblade turret should fit in, no trouble on a glaive. The chassis is essentially the same, and there's only a minimum of difference in parts between the fellblade and glaive (unlike the falchion). The major exception would the turrets themselves in questions, and as Slipstreams has pointed out, that the glaive does not have a demolisher cannon, but instead a an entry hatch, as the glaive turret lacks any hatches. But switching the turrets, should be as easy as switch one on a predator. Now if you don't want the turret, I'd happily go for it Link to comment https://bolterandchainsword.com/topic/313062-fellblade-glaive-turret-compatibility/#findComment-4164966 Share on other sites More sharing options...
