Dillithium Posted September 13, 2015 Share Posted September 13, 2015 Greetings, If you'd be so kind to turn to page 134 of our current DA codex, I have a question about the Whirlwind painted by GW. I'm very curious as to how the mud weathering is achievend on the hull. Does anyone have an idea? My local GW said a layer of Rhinox Hide with a highlight of Gorthor brown, but I feel that it may be typhus corrosion? I really like the look of the mud weathering on that whirlwind, so I'm looking to recreate it. Any tips or advice how to achieve this would be appreciated. I posted it here, rather than PCA because you need the DA codex for the example. I'm not a fan of using pigments, so I hope it's not that. Thank you in advance! Link to comment Share on other sites More sharing options...
shabbadoo Posted September 14, 2015 Share Posted September 14, 2015 Looks like a scrubbed on drybrush of dark brown, followed by a lighter shade of brown put on more lightly using the same technique. Use a larger, low quality brush to do this, as you will be abusing the brush to achieve this look. I would recommend putting some mud on the tracks too, rather than leave them spotless as they are in the pic (silly "Eavy Metal team). Link to comment Share on other sites More sharing options...
elmo Posted September 14, 2015 Share Posted September 14, 2015 I use a sponge. Scortched brown base, bestial brown mid coat, graveyard earth top coat. Each layer is applied progressively lighter and as shabbadoo says... Don't forget the tracks too :) Link to comment Share on other sites More sharing options...
