tjr Posted September 19, 2015 Share Posted September 19, 2015 Usually I run Dante + Priest + Sanguinary Guard. However, what other delivery systems are there for him? I'm thinking about sticking him in either a Command Squad or Vanguard Veterans (without packs) loaded up with Storm Shields and podding them in, for a T2 charge. Hit and Run allows the unit to not be bogged down. Link to comment Share on other sites More sharing options...
CaptainHelion Posted September 19, 2015 Share Posted September 19, 2015 Dante and Death Company is also an interesting way to use that H&R. Instead of avoiding being bogged down, you're trying to maximise the charge benefits (Which, for DC, naturally become rather potent). Could be worth throwing a Priest or Chaplain in there, too. +1 WS, FNP, and another challenge body, or Hatred are both pretty sweet on DC. I usually go the Priest+Guard route myself, as a 2+ crew with FNP and four wounds worth of Eternal Warrior at 4++ is pretty boss. I also like that Dante can so easily split off and mulch something else. Link to comment Share on other sites More sharing options...
Charlo Posted September 19, 2015 Share Posted September 19, 2015 Because Dante is SO strong - you can even put him in a humble assault squad. He'll usually case just enough carnage to win but maybe not slaughter combat. You stay locked, then jump out after finishing the job in your opponents turn :) You can also do the cage match tag team extraordinaires of Dante and the Sanguinor. Link to comment Share on other sites More sharing options...
CaptainHelion Posted September 19, 2015 Share Posted September 19, 2015 True, you can add ICs to The Sanguinor! Why not throw a priest in there, or for extra hilarity, add a Chaplain! Link to comment Share on other sites More sharing options...
evildrcheese Posted September 19, 2015 Share Posted September 19, 2015 I often run Dante with the DC and a Chappy. Rerolls to hit in first round of combat, stacked with rage and furious charge is great, especially when you can rinse and repeat. I usually stick two power fists in the DC, and between the Dante and Powerfist sandwich you have the ap- filling. It's glorious! D Link to comment Share on other sites More sharing options...
LutherMax Posted September 19, 2015 Share Posted September 19, 2015 Slightly off topic but still relevant I think - thoughts on deep striking Dante + unit vs starting them on the table..? Also, Dante at the front to tank or hidden at the back? Link to comment Share on other sites More sharing options...
Charlo Posted September 19, 2015 Share Posted September 19, 2015 Tank, using Los for anything super dangerous IMO. And either are good, his minimal scatter is reliable when combined with a tough unit. Link to comment Share on other sites More sharing options...
evildrcheese Posted September 20, 2015 Share Posted September 20, 2015 Bear in mind you only get the minimum scatter if he's your warlord. Personally, if running Dante I usually have the Chaplain as my warlord and give him the veritas vetae (or whatever it's called). D Link to comment Share on other sites More sharing options...
LutherMax Posted September 20, 2015 Share Posted September 20, 2015 That's the thing - in the past I've found deep striking infantry to be risky. Dante helps with scatter but it still tends to leave the unit vulnerable for a turn. But if you don't DS Dante's trait is wasted. I've considered using another HQ with Veritas but the points often seem more useful elsewhere (Melta bombs on sarges, an extra Sang Guard body etc). More often than not Warlord Traits don't even come into play, or get forgotten. Link to comment Share on other sites More sharing options...
Charlo Posted September 20, 2015 Share Posted September 20, 2015 Even if you take Dante though, you still need another HQ for most detachments! Link to comment Share on other sites More sharing options...
LutherMax Posted September 20, 2015 Share Posted September 20, 2015 I would take one anyway (Priest normally). Just debating whether Vitae is worth it even if you don't plan to make use of DoA... Link to comment Share on other sites More sharing options...
CaptainHelion Posted September 20, 2015 Share Posted September 20, 2015 My local store has a city fight board for 40k, and is basically 80% ruins, so Conqueror of Cities is exceptionally good with lots of jump troops. Link to comment Share on other sites More sharing options...
Charlo Posted September 20, 2015 Share Posted September 20, 2015 I would take one anyway (Priest normally). Just debating whether Vitae is worth it even if you don't plan to make use of DoA... Built in Warlord Traits are nice and I imagine built into the cost of the unit, but unless you build a list around DoA it's not spectacular, and if you do you still have to weather your enemies attacks AND thinks can still misshap. Veritas is just plain awesome. Link to comment Share on other sites More sharing options...
evildrcheese Posted September 20, 2015 Share Posted September 20, 2015 Veritas also help you remember to roll for your traits as you've paid points for it! That infiltrate trait I brilliant, being able to infiltrate my MM attack bike is never a bad thing. Another reason it works so well is for threat saturation, getting slower/stationary (Devs) units is prime positions is just phenomenal. D Link to comment Share on other sites More sharing options...
LutherMax Posted September 20, 2015 Share Posted September 20, 2015 Yeah the Infiltrate one is the obvious target for the Veritas... I've found it difficult to employ sometimes though – the 12" out of LOS / 18" IPS aspect can be tricky, and it normally results in a lot of firepower being ranged on those units. Good as a distraction if you don't use it for your prime units... Link to comment Share on other sites More sharing options...
tjr Posted September 23, 2015 Author Share Posted September 23, 2015 Someone just pointed out to me, that I can't stick Jump Inf in drop pods, so there goes that plan. What about Dante + bikes + Sang Priest (either pack or bike) = majority T5 and FNP (when LOS) against S8 and S9? Link to comment Share on other sites More sharing options...
evildrcheese Posted September 23, 2015 Share Posted September 23, 2015 Someone just pointed out to me, that I can't stick Jump Inf in drop pods, so there goes that plan. What about Dante + bikes + Sang Priest (either pack or bike) = majority T5 and FNP (when LOS) against S8 and S9? Bikes works too. Dante is a CC beast so even jinking they're a threat. Hit n Run then allows them to escape a combat and shoot. Which is very nice. D Link to comment Share on other sites More sharing options...
tjr Posted September 23, 2015 Author Share Posted September 23, 2015 I've read the thread about getting the Sanguinor back on the table, that "my" idea isn't exactly original. Dante Captain on bike, with artificer armor (perhaps not necessary?) and storm shield Sang. Priest on bike Dante in front, Captain behind and Priest at the rear. Unit is majority T5 = harder to kill with small arms fire. If both Captain and Dante have artificer armor they can share anything S7 or below and AP3 or above.If S10 = Dante tanks with EW If S8 or S9 = Captain tanks since he gets FNP If AP2 = Captain tanks on Storm Shield. Weapons: Giving the Captain a Hammer/Fist (Any specialist weapon) since, he'll never get the two-weapons bonus attack due to the storm shield. However, Valour's Edge would also make sense to take advantage of his I5. But then again, if Dante is in the unit, there should be enough AP2 attacks at initiative. Stick a Fist or Hammer on the Captain and Valour's edge on the Priest. Perhaps the Captain should be Warlord and take the Veritas Vitae. Add a bike squad for more grav, more T5 bodies, more jinking Captain (AA, Bike, SS, TH, VV, Combi-Grav) Sang. Priest (Bike, Valour's Edge, Bolt pistol) Dante 4 Bikes (2 Grav, 1 Combi-Grav) = 645p That's disgusting. Link to comment Share on other sites More sharing options...
Brother_Mike Posted September 23, 2015 Share Posted September 23, 2015 I would take one anyway (Priest normally). Just debating whether Vitae is worth it even if you don't plan to make use of DoA... Built in Warlord Traits are nice and I imagine built into the cost of the unit, but unless you build a list around DoA it's not spectacular, and if you do you still have to weather your enemies attacks AND thinks can still misshap. Veritas is just plain awesome. Keep in mind DoA applies to more than just jump infantry. Flyers and skimmers also benefit from the rule, so even if you have 1 stormraven (people usually bring more) then even if you don't deep strike dante and his squad, it's worth it. Personally, I tend to start with my jump infantry on the board just because there is no way to assault the turn they deep strike in. Other units that deep strike but don't need to assault to be effective benefit immensely from more precise DS (see above) Link to comment Share on other sites More sharing options...
LutherMax Posted September 23, 2015 Share Posted September 23, 2015 That is a good point... Link to comment Share on other sites More sharing options...
Charlo Posted September 23, 2015 Share Posted September 23, 2015 Dante + CAD or BSF for characters. Then the rest of your army is Angel's Wrath Intervention Forces of minimal Vanguad+2ASM that cause impact hits to everything within' 6". Vanguard arrive and only scatter up to D6, ASM don't scatter within' 6 inches of Vanguard. Just deep strike loads of them and cause untold S4 hits on the enemy. Load up the ASM with preferred Special weapon and the vanguard with some nice pistols/ shields/ combat weapons. Minimal buy in for this formation is 310 before upgrades (but cost of Jump Packs included as they are mandatory). Pretty good! ..... Had NO idea Descent of angels let you reroll reserve for the appropriate units. That's mad good! Link to comment Share on other sites More sharing options...
Marvin_the_Martian Posted September 24, 2015 Share Posted September 24, 2015 Personally, I tend to start with my jump infantry on the board just because there is no way to assault the turn they deep strike in. Other units that deep strike but don't need to assault to be effective benefit immensely from more precise DS (see above) The argument for deep striking jump infantry, even the ones that want to get into CC, is that if you deep strike about 15" away from your target, they'll only have to survive one round of shooting. If you start them on the board, that could turn into two turns of shooting as you close the distance. Tough choice since that first turn charge would be pretty awesome. If I do run Dante, I use the time-honored tradition of sticking him in a sanguinary guard unit with a priest. Haven't bothered to get too creative with Dante's retinue but I love the suggestions that have been coming up in this thread. Link to comment Share on other sites More sharing options...
evildrcheese Posted September 24, 2015 Share Posted September 24, 2015 I've read the thread about getting the Sanguinor back on the table, that "my" idea isn't exactly original. Dante Captain on bike, with artificer armor (perhaps not necessary?) and storm shield Sang. Priest on bike Dante in front, Captain behind and Priest at the rear. Unit is majority T5 = harder to kill with small arms fire. If both Captain and Dante have artificer armor they can share anything S7 or below and AP3 or above. If S10 = Dante tanks with EW If S8 or S9 = Captain tanks since he gets FNP If AP2 = Captain tanks on Storm Shield. Weapons: Giving the Captain a Hammer/Fist (Any specialist weapon) since, he'll never get the two-weapons bonus attack due to the storm shield. However, Valour's Edge would also make sense to take advantage of his I5. But then again, if Dante is in the unit, there should be enough AP2 attacks at initiative. Stick a Fist or Hammer on the Captain and Valour's edge on the Priest. Perhaps the Captain should be Warlord and take the Veritas Vitae. Add a bike squad for more grav, more T5 bodies, more jinking Captain (AA, Bike, SS, TH, VV, Combi-Grav) Sang. Priest (Bike, Valour's Edge, Bolt pistol) Dante 4 Bikes (2 Grav, 1 Combi-Grav) = 645p That's disgusting. That does sound good. I want to try running this as part of a Flesh Tearers Strike Force as then it's min troop tax, and the chance to get Rage on that death star. Fill out restof the list with more bike and attack bike units and heavy slots. D Link to comment Share on other sites More sharing options...
LutherMax Posted September 24, 2015 Share Posted September 24, 2015 I'm not convinced by the FTSF. Not having to have 2x troops is appealing but you may as well just go Unbound and have none. How many times in a game do you expect to roll 10" charges? Link to comment Share on other sites More sharing options...
Charlo Posted September 25, 2015 Share Posted September 25, 2015 The rage is usually a little, but unreliable bonus. Mainly people take it for the fast attack slots! Link to comment Share on other sites More sharing options...
