Converting a Dark Angels Praetor [Updated]
Emperor's Furor
It's a good idea, but you might have issues trying to get the wings off - they're pretty well molded on. If you're unable to do it, props if you do, then I suggest just getting the extra set of wings from the old DA upgrade sprue.
Got the wings from the Terminator kit today but I think they are a bit to large. Still waiting for the helmet wings from the Veteran squad, if they don't work out I may remove the helmet and just go for the new bare head, although I would prefer it had a proper helmet.
Rule of cool man, no need to come on so harsh.
Rule of Cool depends on it actually being cool. 2' pencil necks aren't cool.
Idk all the positive comments above seem to contradict that notion. YOU don't find it cool, and that's your opinion. Eye of the beholder and all that. Just chill and go make all your models anatomically correct. He doesn't have to if he doesn't want to.
While that is a good idea in principle. I wouldn't overuse this concept of a Equipment carrying watcher.
But that's one of their things.
In 30k too?
Mm that's a good question. I don't know.
Afaik only the Lion has actual contact with the Watchers at the moment.
No one has to know it's actually a Watcher. Just oass it off as a mutant the Praetor inexplicably took pity on and made a slave-squire. Heck, you can make it interesting and have it that the Praetor doesn't even know it's a Watcher.
That head is awful. Helmets won't fit inside that collar though, there's only room for a bare head.
Some of them fit.  I used a MkIII command head (the one with the laurel) with that body and was able to get it in there as long as I faced it towards the notch in the gorget.
The way mine is posed means it needs to look to it's left which is the problem I guess other wise yeah it would fit in looking forward easily.
I've cut off the back collar and added wings to the helmet, positioning the wings was a bit of a pain not sure if it works the way it is atm.
http://i.imgur.com/shE1aNM.jpghttp://i.imgur.com/n8Qb32u.jpg
