Halandaar Posted October 6, 2015 Share Posted October 6, 2015 Hi all, does anybody have any recommendations with regard to a good, strong (and preferably cheap) putty for modelling? I'm in the process of magnetising the weapons on an Imperial Knight so need something to hold the magnets inside the "sockets" on the weapons. Any suggestions? Thanks! Link to comment https://bolterandchainsword.com/topic/314560-putty-recommendations/ Share on other sites More sharing options...
Grotsmasha Posted October 10, 2015 Share Posted October 10, 2015 As long as the magnets won't be seen, super glue is much more effective at holding magnets in a slot rather than puttying over them. If you're intent on putty, Green Stuff via eBay or Amazon is significantly cheaper in larger quantities than you'll get from GW. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/314560-putty-recommendations/#findComment-4193385 Share on other sites More sharing options...
Atia Posted October 10, 2015 Share Posted October 10, 2015 I use a mix of milliput and green stuff ^^ Link to comment https://bolterandchainsword.com/topic/314560-putty-recommendations/#findComment-4193394 Share on other sites More sharing options...
Gurth Posted October 10, 2015 Share Posted October 10, 2015 If the sockets are a tight fight for the magnets, use superglue as recommended. If they fit but not very tightly, use two-part epoxy glue, as that will fill small gaps much better than superglue will. Link to comment https://bolterandchainsword.com/topic/314560-putty-recommendations/#findComment-4193513 Share on other sites More sharing options...
