jimbo13 Posted October 7, 2015 Share Posted October 7, 2015 Hey folks, Like the title says!!! How on earth do I sculpt unification era lightning bolts? Didn't see it specifically in tutorials so I was curious if the community had sage advice/wisdom? Pictures would be helpful. Thank you everyone!!! -Jimbo Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/ Share on other sites More sharing options...
Brother-Chaplain Kage Posted October 7, 2015 Share Posted October 7, 2015 I've done a few lightning bolts and Raptor Imperials icons here and there. http://i.imgur.com/344D1Pe.png http://i.imgur.com/fxnZfdz.png Like a lot of sculpting, it's all about breaking down what you're wanting to do into simple shapes. For the skinny bolts on the Raptor Imperialis, I broke it into three different little lines and joined them together. For the chunkier bolts on the dreadnought's chest, it's two shapes - a rectangle and a thin scalene triangle. To make it easier, you might sculpt them on a flat surface instead of on the model iteslf so you can then remove them and glue them into place later. I would also suggest having reference material handy any time you're sculpting something. Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/#findComment-4190313 Share on other sites More sharing options...
Atia Posted October 7, 2015 Share Posted October 7, 2015 what BCK said - model it on a flat surface and if you are happy with it, add it to the model^^ i would also use not pure green stuff, but a mix of miliput and green stuff, that makes it easier to work with and it gets realy hard once it's dry^^ Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/#findComment-4190339 Share on other sites More sharing options...
jimbo13 Posted October 7, 2015 Author Share Posted October 7, 2015 Awesome thanks you two!!! I'll keep fhose tips handy when I finally start up my project Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/#findComment-4190542 Share on other sites More sharing options...
Ovidius Incertus Posted October 7, 2015 Share Posted October 7, 2015 what BCK said - model it on a flat surface and if you are happy with it, add it to the model^^ i would also use not pure green stuff, but a mix of miliput and green stuff, that makes it easier to work with and it gets realy hard once it's dry^^ Which color Milliput is preferable? Grey or white? Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/#findComment-4190895 Share on other sites More sharing options...
Atia Posted October 7, 2015 Share Posted October 7, 2015 what BCK said - model it on a flat surface and if you are happy with it, add it to the model^^ i would also use not pure green stuff, but a mix of miliput and green stuff, that makes it easier to work with and it gets realy hard once it's dry^^ Which color Milliput is preferable? Grey or white? i use milliput: standard yellow - grey Link to comment https://bolterandchainsword.com/topic/314590-suggestions-on-how-to-sculpt-unification-lightning-bolts/#findComment-4190903 Share on other sites More sharing options...
