WolfMonk Posted October 15, 2015 Share Posted October 15, 2015 Found this on a board:http://ttadapters.com/ http://s15.postimg.org/lhf5abttn/image.png http://i14.photobucket.com/albums/a347/ravenwing1/standard3/695AA988-F454-4C04-BE1E-9104879866D2_zpsuqzujjii.jpg Its getting really good reviews. Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/ Share on other sites More sharing options...
Grotsmasha Posted October 19, 2015 Share Posted October 19, 2015 I'm fairly sure the Kickstarter was over in Amicus. They're pretty reasonably priced too. Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/#findComment-4200703 Share on other sites More sharing options...
Komodo Posted November 9, 2015 Share Posted November 9, 2015 Really nice. My only concern is that gap between two halves... Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/#findComment-4220243 Share on other sites More sharing options...
Trevak Dal Posted December 17, 2015 Share Posted December 17, 2015 Really nice. My only concern is that gap between two halves... Maybe some greenstuff? Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/#findComment-4254690 Share on other sites More sharing options...
JGeils81 Posted December 17, 2015 Share Posted December 17, 2015 I think if I decide to adapt to 32mm bases I'll just make my own similar to these, can always add designs or w/e into the sides and just make copies, ooh new project, damn. I know I wont be replacing all the 25mm bases I've done. Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/#findComment-4254932 Share on other sites More sharing options...
Ultra kblock Posted December 30, 2017 Share Posted December 30, 2017 · Hidden by Grotsmasha, December 31, 2017 - Threadromancy Hidden by Grotsmasha, December 31, 2017 - Threadromancy I have some of these adapters to update my space marines. They fit will around the 25 mm bases and the gap has not been an issue for the sand/rocks I use with my bases.Once the adapters are glued in place, A little thicker glue (even elmers) in the gap fills it easily. Link to comment https://bolterandchainsword.com/topic/314959-easy-32mm-solution/#findComment-4970483
