Tempestus Scions Alternative Plasma Guns
Working on making a few storm trooper squads, amazing kit but unfortunately the plasma gun pose is going to look silly with 2 plasma gunners in 5 man squads. The model has the plasma gun on his hip, and is pointing with his other arm. I don't really see any way to convert the army with the gun in such a way that it would look different-gun and arm is all one piece. I imagine space marine plasma guns are too big, so not sure on what other kits to look at, unless the space marine one would kit to size.
I made these to use as henchmen for an inquisitor. Worked pretty well, and it's a fairly easy build. You just use space marine plasma pistols and replace them for the hot shot lasgun barrels.
http://image.bolterandchainsword.com/uploads/gallery/album_945
It's possible this link won't work, my iPad is a pig when it comes to forums. If it's a dud, I'll re-do it on the pc after breakfast.
EDIT: this should work.
bingo.
Only thing I can think of is taking some from the Imperial Guard command squads, cadian for sleeved arms or Catachan for bare. But I reckon the space marine gun might be ok size. depends on the marine kit.
I forgot about the command squad thanks that's a good place to look.
Stercus those look great, plasma guns with scopes is a great idea I'll look into that as well.
bingo.
Those look really great. I can see myself borrowing the idea. ;)
Ive used marine ones on mine for the same reason :D Should be centre squad (Though one looks a bit wonky here...) i just used the grenade launcher arms around it, because i was never going to use grenade launchers :D
http://i27.photobucket.com/albums/c188/Noserenda/Models/Scions.jpg
